Old 12-04-2023, 11:32 PM   #1
jeff74
jeff74's Avatar
Old distributor refresh, timing questions
Was messing with my distributor today, I bought a moroso advance kit and gear shims. The old springs are pretty loose and the gear has about .080 of play. I shimmed the gear to about .015 of play and the distributor will still drop in and sit down on the intake without a gasket, so I think I'm good there for clearance.
I installed the included copper bushing, the old plastic one had fallen off. From what I'm figuring (and online calculatoring) .. I have about 17 degrees of mechanical advance, so 34 crank degrees?
Am i down to welding the slot closed a bit to limit the advance? From what I'm reading the vortecs like 8-10 degrees at idle and 30-32 total?
1971 GMC C25 with a 'refreshed' 1996 Vortec 350/SM465
jeff74 is offline   Reply With Quote
Old 12-05-2023, 01:36 PM   #2
RichardJ
Re: Old distributor refresh, timing questions
>>I shimmed the gear to about .015 of play and the distributor will still drop in and sit down on the intake without a gasket, so I think I'm good there for clearance.<<
It is good that you checked it. 30 years ago I had shimmed the shaft on my six cylinder HEI and found that it would not sit in all the way and was pushing against the oil pump.
>>I installed the included copper bushing, <<
Hobby stores have copper tubing in incremental sizes that will slip inside each other. Easier to build up and work back if needed.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 12-05-2023, 03:01 PM   #3
jeff74
jeff74's Avatar
Thanks.
Good idea with the copper tubing, I probably have a couple sizes around here..
Old 12-05-2023, 06:05 PM   #4
geezer#99
geezer#99's Avatar
Do you have the distributor part number?
I have a motors manual with the timing specs.
Might be in there.
geezer#99 is online now   Reply With Quote
Old 12-05-2023, 07:29 PM   #5
jeff74
jeff74's Avatar
Might be in there.
I have 1112002 9J30, if that's the part number..
Old 12-05-2023, 08:47 PM   #6
geezer#99
geezer#99's Avatar
Here you go.
It’s listed in the 69/70 year.
Old 12-05-2023, 08:50 PM   #7
geezer#99
geezer#99's Avatar
Here’s a better pic.
Old 12-05-2023, 10:06 PM   #8
jeff74
jeff74's Avatar
Cool, thanks.
I guess I was pretty close, I figured 17 degrees of mechanical advance by making some marks and eagle eyeing it..
I ended up welding a short piece of key stock to the distributor plate as a stop , it's set right around 10 degrees for now
