Old 01-04-2024, 06:23 PM   #1
PbFut
Quick window regulator question
My window cranks have about 22.5° slop from up and down direction. Both my cranks have it.. inspection of hardware looks good. Is there normally that much give between rolling up and rolling down? Thanks for help.
PbFut is online now   Reply With Quote
Old 01-04-2024, 07:51 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Quick window regulator question
Do you mean the windows tilt by 22.5 degrees? I believe that is not normal for them to tilt at all. I suggest remove the inner panel and inspect the window regulator. They are supposed to have the plastic rollers in the tracks. There are certain spots in the track where the roller can be inserted, otherwise they stay in the tracks when the window is rolled up and down.
dmjlambert is offline   Reply With Quote
Old 01-04-2024, 08:26 PM   #3
truckster
truckster's Avatar
I'm pretty sure he means the window cranks rotate that much without moving the window. That does seem a bit excessive.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 01-04-2024, 08:32 PM   #4
PbFut
No I am referring to the rotation of the crank handle. The tracks and wheels are all in very good condition with no apparent play of significance. The play seems to be in the crank gears. It has been decades since I have owned a manual window. I cannot recall how much play was in the handle back in the day. I have no problem replacing the regulator but from what I can tell the play in rotation of the window crank handle is normal. I am just looking for confirmation.
Old 01-04-2024, 08:49 PM   #5
dmjlambert
dmjlambert's Avatar
I have that much free play in the crank, and my window works fine and I never noticed it before you pointed it out.
Old 01-05-2024, 10:50 AM   #6
leddzepp
Moderator
leddzepp's Avatar
If it functions as it should I’d leave it alone
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-05-2024, 11:01 AM   #7
A1971Blazer
A1971Blazer's Avatar
There's no doubt it probably has some wear, but if it still works...it still works
I have a brand new NOS regulator....I'll check to see how much backlash it has
Update: 10º-15º backlash before engagement and movement
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-06-2024, 12:21 PM   #8
PbFut
Thanks for input. Above info gives me a reasonably good feeling the play in handle is close to normal. The tracks and rollers are clean with no grease and still function very well when the widows is properly controlled. The fuss in the guide tracks is very bad shape and allow window to rack and bind some. If I control window it rolls up and down smoothly. I plan to rebuild the vent windows and replace all rubber and fuss. I think the result will be good.
Old 01-07-2024, 08:39 PM   #9
joeydurango
joeydurango's Avatar
Maybe mine are worn out but both driver and passenger sides have at least 22 degrees of free movement when changing direction. That's only 1/8 turn, seems reasonable to me.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 01-08-2024, 01:31 PM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I installed NOS everything of late. Like post 7, the cranks engage approx. 10°, basically a click.
If it's a driver, then if they aint broke don't fix em?
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
