Old 02-18-2024, 01:25 PM   #1
cag
Active Member
1962 gmc rear gas tank options???
So the lmc kit will not work, what have yall done to put a rear tank in a 62??
Thank you!!!
cag is offline   Reply With Quote
Old 02-18-2024, 04:50 PM   #2
62bagger
62bagger's Avatar
Re: 1962 gmc rear gas tank options???
I used a 64 Mustang tank. I had to make a mounting bracket because it is narrower than the frame rails but it tucks up nice. The kits that I looked at hung below the bumper and I didn't like that look.
62bagger is offline   Reply With Quote
Old 02-18-2024, 05:30 PM   #3
SkinnyG
SkinnyG's Avatar
I did a 90's S10 Blazer tank, but the bed floor is also raised 4"
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 02-18-2024, 08:44 PM   #4
forestb
forestb's Avatar
I got one from Boyd’s and it’s awesome. I ran a plastic fuel cell for years and it was horrible.
https://fueltankparts.com/collection...hoCp5UQAvD_BwE
forestb is offline   Reply With Quote
Old 02-19-2024, 01:56 PM   #5
verdell
verdell's Avatar
I did the '94 S10 Blazer tank also. It fit between the frame rails, it's 20 gallons and didn't hang as low as some of the others like the standard issue K5 Blazer tanks. It's also FI ready if you choose to go that route...
verdell is offline   Reply With Quote
Old 12-29-2024, 04:03 PM   #6
cag
Active Member
does it mount on the top flange of the tank all the way around?
what did you use for a sending unit? and tank fill??
Old 12-29-2024, 04:03 PM   #7
cag
Active Member
any pics of this??
Old 12-30-2024, 01:43 PM   #8
sirJim
I did a newer suburban 25 gal. in my 62 Suburban. Changed the spout for the side fill and made a cross suport to hold the "straps" other than that fit great.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 12-30-2024, 09:18 PM   #9
AcampoDave
AcampoDave's Avatar
More than anything else, I didn't want my rear tank to be hanging below the bumper. I asked this site for help, and the members came through. Here's the thread. http://67-72chevytrucks.com/vboard/s...d.php?t=621177
AcampoDave is offline   Reply With Quote
Old 12-30-2024, 10:58 PM   #10
62bagger
62bagger's Avatar
The tank hanging low was the reason I went the direction I took. I did not want to see the tank from the rear of the truck.
Old 01-18-2025, 11:53 AM   #11
62 Barnfind
62 Barnfind's Avatar
I have the POL 60-62 tank.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-20-2025, 03:06 PM   #12
bigmoe
bigmoe's Avatar
Tanks Inc USPT-GH 15 gal tank. It has two options for fill location. It doesn't hang low and you can buy it with built in fuel pump for EFI.
bigmoe is offline   Reply With Quote
Old 01-21-2025, 05:18 PM   #13
verdell
verdell's Avatar
Originally Posted by cag View Post
any pics of this??
Unfortunately, I don't have any detailed pics of my setup but it's very similar to SirJim's '62 Suburban. The S10 Blazer tank doesn't hang quite as low though and my straps are hung front to rear.
Old 01-22-2025, 03:02 PM   #14
cag
Active Member
this tank mount between the spare tire mounts? what did you do for top strap?
Old 01-22-2025, 08:05 PM   #15
AcampoDave
AcampoDave's Avatar
Same one I decided on too
Old 01-22-2025, 09:26 PM   #16
bigmoe
bigmoe's Avatar
Spare tire mounts?
I made 4 corner brackets that hold the tank in place and straps underneath.
Old 01-23-2025, 03:42 PM   #17
cag
Active Member
Spare tire mounts?
the two formed crossmembers at the rear of the frame
Old 08-08-2025, 07:47 AM   #18
cag
Active Member
[attach]Name:  Resized_20250807_184519.jpeg
Size:  60.8 KB[/attach] finally got the tank in, tanks for all the help....
Old 08-10-2025, 09:34 PM   #19
slepysal
slepysal's Avatar
Looks great how about a write up?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-11-2025, 07:07 AM   #20
cag
Active Member
gm sir, its made from 1 x 2 x .125 tube, I spaced it down 1" which puts the fill neck right at the top of the wood for the bed, I bought a lil door kit from tanks inc, the tank is a mustang tank...I can get the the bolts for the bed cross supports from under the frame with a swivel socket.
