Old 06-17-2024, 06:55 PM   #1
skokie
skokie's Avatar
68 C10 throttle rod to cable
I thought there was a faq or writeup on how to convert from a throttle rod to cable but I can't find it. Can someone post it up?
Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-19-2024, 03:51 PM   #2
skokie
skokie's Avatar
Re: 68 C10 throttle rod to cable
Ttt
68 build thread
Old 06-19-2024, 04:50 PM   #3
weq92f
weq92f's Avatar
Here are some search hits I came up with:
https://67-72chevytrucks.com/vboard/...d.php?t=371099
https://67-72chevytrucks.com/vboard/...00#post1383300
https://67-72chevytrucks.com/vboard/...t=rod+to+cable
EDIT: I think that second link above is what you're after.
Hth
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-19-2024, 05:05 PM   #4
skokie
skokie's Avatar
That's it! Thanks weq92f. I appreciate it
68 build thread
Old 06-19-2024, 05:18 PM   #5
loudchevy
loudchevy's Avatar
Saved, Thanks for the links!
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 06-19-2024, 06:56 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Those are some old links. Unfortunately the LFD guy stopped doing business about 15 years ago. And Rockcrawlin's last post was in 2018.
Putter's old post of 08/26/2005 has the best method. About what I did.
From a '72 Chevy truck, I pulled the Gas Pedal and the plastic pivot triangular piece.
I bought an aftermarket cable assembly from my local Hot Rod Shop. [I'm looking for pix, but my new laptop doesn't have the shots I wanted.]
Works great.
Old 06-19-2024, 09:43 PM   #7
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: 68 C10 throttle rod to cable
i did my 69 suburban the difficult way, i had a junk 72 cab and i cut out the section of the firewall where the pedal and cable were attached, drew a line around the 72 section onto the 69 firewall and cut it out, trimmed until the 72 piece fit perfectly and welded it back together. it was actually easier than it sounds since the front clip was off and the engine was out.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-20-2024, 01:14 PM   #8
LNP
Heres a link to the two that I read over before doing mine. If you get any questions let me know and I will try to help and/or I could post pics of my pedal mount and carb linkage bracket.
https://www.67-72chevytrucks.com/vbo...d.php?t=170383
https://67-72chevytrucks.com/vboard/...d.php?t=530828
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
