Wanted 67 nos door handle
Wanted 67 only nos drivers side exterior door handle, the body shop was supposed to modify the door to fit the 68-72 handle, when I tighten the bolts the handle tilts and leaves a gap at the top of the handle, any help would be appreciated, thanks Adam
Re: Wanted 67 nos door handle
Ttt
![]() ![]() Join Date: Jan 2005
Thank you do you know if the part number is correct for a 67 only handle
The part number on the box is correct for 67 only. I don't know about the casting number on the back of the handle though.
Thank you I asked for better pictures but never got any
The casting number on my original 67 handle does not match the one on his.i suspect a 68-72 handle he has there.
Thank you
![]() Join Date: Jan 2004
Even though the casting # is different it may be 1967 correct. Ask the seller if the bolts thread straight in or at an angle & you will get a positive ID.
Thanks Mike the seller is not responding
![]() Join Date: Dec 1999
I'm pretty sure Key Parts make a repro 67 only door handle.
See here: https://www.ebay.com/itm/155569362173 I bought a set a while back but have not installed them. When I get to my shop. I'll try to take a picture to confirm they are correct. |
Here's a picture of a NOS Passenger side handle with the Key Parts Drivers Side Handle
#13 |
Another View
#14 |
One More
#15 |
My Pictures make it hard to tell, but the screws on both go straight in. Not angled down like 68 and later.
#16 |
Thank you for the information I'm sure that will be helpful for others also
| Bookmarks |
