![]() Join Date: Jan 2016
Door glass seals
Hey everybody,
I tried to do some searching on this and found some old posts, so I wondered about reviving this discussion. I bought some custom window seal kits for my 72 C20 from LMC. https://www.lmctruck.com/door-compon...and-components These don't seem to fit at all. I called LMC and they told me the pieces were 27" long, which wouldn't fit without being trimmed. Even when trimmed they don't fit properly along side the triangle vent window. Has anyone got any suggestions and advice on another brand or a way to make these fit and look good. I've got some photos below of my attempts. Thanks!
The Dude abides.
Re: Door glass seals
I feel your pain , they are a P.I.T.A ! I dont have the outer on my drivers door because after the second attempt (destroying the Part) I gave up .
![]() Join Date: Jan 2015
Lmc seal suck. There felt kit worked good. But my door seals hardly touch glass to seal
The Older Generation
This is what I always used but it looks like they are discontinued. Maybe Classic industries just don't handle them any more. https://www.classicindustries.com/product/cr1073.html They were made in the USA by Clark Industries they were the nicest ones I could find at the time..... I know that Repops made the weatherstrips for Precision at one time but Now I'm not sure. By their web site it looks like they still make the window kits. https://www.repops.com/product-searc...yr=44&ne=0&kw= I would check with GMCPauls and see what they say. https://gmcpauls.com/ .
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-17-2024 at 12:32 PM. |
![]() Join Date: Feb 2022
The ones from GMCPauls requires trimming. I am a week or so away from installing them.
Sorry, I don't recall if they were in a labeled wrapper or not and can't recall brand. |
I bought LMC first and they are crap. Bought Steele rubber. Also crap. Bought precision and they are a great fit. No trimming. Just make sure the slots inside the door are flat and not bulged out. If not flat it won't fit properly. Also as someone on the forum stated on the 72 there is a screw on the door under the wing window. You need to slightly loosen the screw to slide in the outer piece. No matter what you do they are still a real booger to install. You'll be shaking by the time you're through. The screw I mentioned is in your first photo. It's in the indentation on the door below the wing.
#7 | |
https://www.prp.com/product/detail/1...ickup&type=All
The Dude abides.
#8 | |
I've got a set on order. Should be here tomorrow seeing as they are 3 hours away from me over in Wisconsin. Perhaps I'll get them in this weekend. I'll post pictures as I go and keep ya updated. Thanks again the for advice. Appreciate it.
The Dude abides.
![]() Join Date: Apr 2016
I recommend reading my experience with it and the guidance I received from the folks here on the forum. And the pictures. The felts fit on the inside of the glass channel, and you need to shave and smash them in order to fit. Smash it in a vise. The squeegee may need to be trimmed just a little. https://67-72chevytrucks.com/vboard/...d.php?t=738367
Watch the install video on precision. Remember to have the slots in the door flat or it will end up with a gap between molding and door. These are pretty much a one shot deal. You'll probably booger them trying to remove. My slots were easy to flatten with a broad tip screwdriver. Just protect the window. I also had the door panels off and removed the window stop inside the door. You can then lower the window a little more and give yourself a little more wiggle room. Anyway it's still no fun. You can do it. Also, use tape on your door paint.
Update - - Got the window seals from Precision out of WI and they feel like they are waaaay better quality than LMC, so thank you Howzzzit for a heads up on that one. I'll try and get them installed tonight and we'll see how it goes.
Man, I love this forum board. This place is so much better than any YouTube channel for info. We need to arrange a get together with all of our community assisted repaired trucks.
The Dude abides.
#13 |
Subscribed!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
#14 |
I got the door glass seals in last night and they are a lot better than LMC's seals. These were super easy to install and are high quality. I paid $84.00 for these before shipping and have learned as I've gotten older, you get what you pay for. I loosened the screw in the window vent and that helped to get the seal seated. The video on Precision's website was really helpful as well.
Here's their website again if anyone needs it. https://www.prp.com/ I will definitely be buying more parts from them. Below are the installed photos. A little wavy, but definitely better than what I had. Thanks to everyone for the input.
The Dude abides.
#15 |
![]() Join Date: Mar 2000
We've offered Precision seals for 25 + years now. Top notch company that stands behind what they manufacturer.
https://gmcpauls.com/Pickup.htm Paul Jr @ GMCPauls |
#16 | |
![]() ![]() Join Date: Feb 2009
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#17 |
working on this too. can anyone tell me what the width of the window slot should be prior to installing the seal and felt?
1970 sb stepside 4.5"f / 5"r; 350, edelbrock 4bbl 1406 650cfm; 20" Detroit Steel ambassadors ; front disc conv; '68 front clip; PROJECT taking too long haha
#18 |
![]() Join Date: Sep 2014
Precision Seals all the way.
I got mine from Wes Hepp @ https://www.classicheartbeat.com/ A little trimming required.
Sam 1972 C10 LWB, Hugger Orange/White 2025 GMC Sierra 1500 Elevation, Sterling Metalic |
#19 |
![]() ![]() Join Date: Jul 2003
Those look spectacular.
The ones with the bright stainless bead were not ever factory installed on trucks, right? My '72 Cheyenne Super, and '70 Blazer CST just had the normal black.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#20 |
Unsure about them originally from the factory.
![]() Very pleased that this stainless option was available from Precision. My Windshield, Rear window and Door to Cab seals are also from them. Other reproduction part manufacturers could learn a lesson from Precision about aftermarket restoration parts for quality and fitment.
#21 |
They were factory on my 72 Cheyenne C10. I replaced with same from Precision. A little extra bling.
#22 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Did did my truck a few weeks ago and used Precision products. Very happy with the results and not that hard to install.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
#23 | |
Driver's side front 1-1/8" Driver's side rear 1" Passenger side front 1" Passenger side rear 1-1/16"
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
| Bookmarks |
