69 C10 with a 6l90 transmission
I am looking for your help. I read a lot of posts about this swap and from what I read I just needed to cut for the high hump trans tunnel. As you can see I did that and placed the cab on the frame and you can see that the tail shaft and that 3 bolt flange are inside the cab. So what have I done wrong?
| Bookmarks |
| Tags |
| 6l90, ls swap, trans tunnel |
