Old 09-05-2024, 06:32 PM   #1
vardenafil
what size motor mount shims needed?
i just replaced newish rubber motor mounts with poly ones. my engine still sits too low. what size spacers should i try? i need to bring up the motor 1/2 to 3/4 of an inch.
vardenafil is offline   Reply With Quote
Old 09-05-2024, 09:21 PM   #2
MikeB
MikeB's Avatar
Re: what size motor mount shims needed?
If it was low with stock mounts and poly mounts, something is not right. Maybe too high at the trans cross member?
BTW, ideally the the carb would be level, or close to it.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-05-2024, 10:08 PM   #3
RustyPile
RustyPile's Avatar
As they came from the factory, shimming the motor mounts was not required.. Either those poly mounts are incorrect, or something is amiss with the frame brackets.. What are you referencing to determine correct engine height??
RustyPile is offline   Reply With Quote
Old 09-05-2024, 11:20 PM   #4
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Pics needed.
~Steven
Simi Valley, CA
Old 09-07-2024, 12:23 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I have never needed shims. Pics are definitely needed...
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
