Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Old 09-16-2024, 12:12 AM   #1
Rene Nieto
Fuel gauge Question
Hoping someone can give me some suggestions on solving my fuel gauge problem. Sometimes it will read half full or empty etc. when i know that it has gas . If i hit on the gauge cluster it will move the needle. So i'm thinking it's not a sending unit issue , but more of a gauge cluster issue ? Any idea what's causing this would be appreciated. Thank you
castiron9
Rene Nieto is offline   Reply With Quote
Old 09-16-2024, 04:41 AM   #2
franken
Re: Fuel gauge Question
The gauge is probably the most reliable bit in the system. Then comes the float in the tank and wiring.
franken is offline   Reply With Quote
Old 01-06-2025, 11:33 AM   #3
tucsonjwt
I had the same problem on my 83. I replaced the sending units in both tanks and still had the problem. I replaced the gauge and problem was fixed. I used aftermarket Spectra brand sending units and the needle on the gas gauge will bounce around when the truck is in motion. I think AC Delco sending units would not do this but they cost about $150 each and the Spectra units were about $50 each. The Spectra units do display the correct fuel level when the truck is not moving, after the needle settles down.
tucsonjwt is offline   Reply With Quote
