Coolant dripping from front driver side fender
All the sudden I have coolant dripping out of the bottom of the front driver side fender. Just started. Truck hasn’t been cranked in at least a week if not closer to two weeks. any ideas as to why and how to fix? Last thing I did was bleed the sysyem add an overflow hose through the bottom front of the passenger fender well. I also topped the coolant off but that’s been 2 or 3 weeks ago.
![]() ![]() Join Date: Jul 2003
It's not the heater core if on the drivers side. Must be a leak from the upper radiator hose, or water pump if it's slinging coolant. A visual inspection is in order..
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
![]() ![]() Join Date: Jul 2002
Re: Coolant dripping from front driver side fender
also make sure ur drain plug is intact. I have had a radiator with a plastic plug just cracked on me and started dripping.
Here are some pics. Doesn’t appear to be leaking from upper hose or drain plug. Mostly under the driver side corner. There’s a little on the right side under the return hose. Couldn’t get a picture. Nothing in between.
Loosen the fan shroud and pull it away so you can look at the seams and cores to see if there is a drip there.
My guess is it's coming from your radiator and it's just dripping there because it's a low point.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson 1972 K/5 Blazer CST 4WD 1963 Corvair Monza Spyder Turbo convertible 1995 Camaro Z/28 |
![]() Join Date: Apr 2016
"Last thing I did was bleed the sysyem add an overflow hose through the bottom front of the passenger fender well. I also topped the coolant"
I suspect spilled coolant running along the radiator support and dripping out of the drivers side. Also, unless you have a coolant recovery tank, these systems do not run with a completely full radiator (normally they are down an inch or so from the top). If you filled the rad to the top and then ran the vehicle it will dump some coolant from the overflow until the system reaches its happy level. This may be what you are seeing.
1972 GMC K2500 Super Custom Matt |
Most likely. Radiator is brand new though so it’s strange to me that it just started out of the blue. Hasn’t been run in weeks and no work has been done in the area it’s coming from.
Couple days ago my radiator started leaking. The culprit turned out to be a big rat. Just sayin. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#10 | |
![]() Join Date: Jun 2022
The ol' "rinse and hope it doesn't repeat" test seems appropriate
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
Noticed the radiator cap is 9# not sure if that may have anything to do with it and the fan shroud doesn't fit up flush with the radiator. Mounts to the radiator hold down brackets but has about a 1/2" gap between the radiator support and the back of the brackets.
#13 |
Original caps are 15#, which will make any leaks worse.
| Bookmarks |
