![]() Join Date: Feb 2022
Upgraded cab insulation discussion
Continuing with the fire damage, I ended up stripping the firewall engine side to metal with wire wheel and epoxy prime.
The interior side of firewall got so hot it charcoaled the jute insulation of the center section OEM pad and a bit of the inside cowl jute and a small part of the left pad in area of gas pedal. A question for those who have upgraded the insulation. Was it worth it? Does laying the rubberized material behind the gas tank add any benefit? Floor? The cab is gutted except tank. Now is the time to do the extra insulation if it is worth it. I need to watch my add-ons to this repair or a blown bank account could easily come about. Seems this stuff does add up so I am looking for input. Thanks for help |
Re: Upgraded cab insulation discussion
No opinions?
![]() Join Date: Nov 2013
I did a build from scratch, so the inner firewall was bare metal. I used Lizard Skin heat coating as well as the sound deadener coating. I also glued on 3/8" thick jute insulation with the foil on both sides, as high as I could get it up under the dash.
I don't have a comparison, but it's cool and quiet. In your case, if it was me, I would use the self adhesive (Dynamat, Fat Mat, etc) then perhaps add a layer of ¼" jute over that everywhere it was feasible.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer .............
This is what my 68 Cab looked like before the carpet went down. First layer was Hush Mat. Second layer is double sided foil jute insulation. Then the stock carpet. I'm running headers with my LS swaps and I think it really helps.
Also under the cab over the header area I use insulation from DEI. One side is kind of like a dimpled foil. Then in the middle kind of a fiberglass insulation and then super sticky glue to stick it to the sheet metal. |
![]() ![]() Join Date: Jul 2003
I used Dynamat on my Blazer. It is quieter in the cabin than it ever was!
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
![]() Join Date: Jul 2021
I sprayed the interior of my 72 C20 with lizard skin sound deadener and also the heat barrier. Then I applied a layer of the Flat Line Barrier. My carpet with jute backing over all of this. Best thing I ever did for the interior of the truck. It is now super quiet and virtually no floorboard or firewall heat from the exhaust or engine. I run headers with 3" exhaust and 40 series flow masters. No problem talking to anyone and I don't have to crank the radio up to listen to it.
Darrell ![]() 1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck) 2000 S10 Xtreme (Black Magic) (My Drag Truck) |
Really good input. The lizard skin product under the dynamat sounds like a really nice way to go. I would be looking at 500 plus for the lizard and gun and another 250 for the dynamat. Then the jute and carpet. I am not sure I want a Cadillac truck relative to noise isolation. Heat is more my issue. I prefer engine over music noise anyway.
#8 | |
![]() Join Date: Dec 1999
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
p/o of my truck had laid down the home store roll of kill-matt stuff. It didn't do anything for heat so on top of that I put a layer of foil-on-both sides insulation (not expensive) and topped it with the full jute backed carpeting. This and later sealing up firewall leaks and the kick vents tamped down the heat problem pretty good! -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#10 | |
I'm sure this is too late, but Lizard skin is paint with ceramic beads. I bought the ceramic beads and mixed it with a qt of Rust-Oleum latex paint. Put it on with a mini roller and brush. It dried with a light sandy texture. It creates a radiate barrier that reflects heat. Its tough as nails even with latex paint on my 1973 international build, I've since added 5/8 thick dense vinyl foam padding for more insulation. I too added the DEI like LS Short Box. to my 1971 chevy build on the fire wall and tranny tunnel as a radiate barrier works best under the vehicle. On the cheaper side, you can use foiled foam core You need to use spray glue to attached to the underside. I then covered it with foil tape to give it more durability, it still there 10 years later.. 1973 international build |
One thing to save cash is that Dynomat type products work to reduce noise generated by flat sheetmetal panels. So you only need to cover those areas, not ever square inch of the cab. Panels with compound curves are virtually vibration free and won't resonate sound.
If in doubt tap the part of the panel if it sounds dead it's likely it won't resonate sound.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
| Bookmarks |
