Old 11-04-2024, 06:28 PM   #1
skokie
skokie's Avatar
What is this wire for?
Hello
I was looking for my service manual so I can answer this myself but have not been able to locate it. Can anyone tell me what this pink wire is for (circled in blue) ?
Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-04-2024, 07:00 PM   #2
jaros44sr
jaros44sr's Avatar
Re: What is this wire for?
GM always used pink for a switched circuit, should be tied into your ignition
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-05-2024, 02:23 PM   #3
PbFut
Looks like the positive lead for a tach.
PbFut is offline   Reply With Quote
Old 11-05-2024, 03:27 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by pbfut View Post
looks like the positive lead for a tach.
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-05-2024, 05:50 PM   #5
skokie
skokie's Avatar
Thanks!
68 build thread
Old 11-08-2024, 07:34 PM   #6
LNP
Originally Posted by skokie View Post
Hello
Thanks!
It looks like it tees two directions. If I followed it correctly one goes to the instrument cluster and the other goes to the backup light switch. And a pink wire from the ignition switch to the fuse for them.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 11-08-2024, 11:03 PM   #7
PbFut
No. BU light would be a direct wire into the ribbon wire plug at the firewall that runs to the light switch and into main harness. Not connected to the switch but uses the path. The tach wire (pink) is a switched line. It will have a second plug close to the fuse box connector to dazie chain additional options. The aux battery relay trigger uses a pink wire and is supposed to be connected to the unfused terminal towards the right of panel. Stands to reason the tach would go to same pin and dasie chain if both option were on the truck. I am redoing all the wire currently and that seem most logical setup. It's unfused but apparently how it was from factory
Old 11-10-2024, 02:53 PM   #8
LNP
Follow the pink wire coming out of the fuse box and see where you see it goes
Harley
