Need way quieter exhaust now...
I built my exhaust using the Flow Master Delta 44s in 3.
The mufflers are under the box, not the cab. I had the original Flow Master 40 Series in 2 1/2 before on the old engine, which had the mufflers under the cab, and out the sides, just in front of the back tires, and it was way quieter. I thought the Delta 44s were gonna be quieter, but aughhhhh...no. I want quieter exhaust...I can add cutouts if needed. The wife is not too keen on going for drives when its this loud. Any recommendations? PS: I used v-bands on the muffler inlets and outlets, so it should be easy peasy to change them out.
"If it ain't broken, fix it 'till it is!" |
Re: Need way quieter exhaust now...
I've heard that Dynomax Super Turbo are nice compared to most.
I am enjoying my Magnaflow 11266 mufflers. They are on a Blazer with the top off. I have 3 exhaust.
I thought that I went with 3 exhaust but actually it is 2.5.
I purposely designed my own exhaust system to place the mufflers further behind the cab on a long bed K10. I also went with Magnaflow in a 4" x 9" (11225, 2.25"). I was amazed at how quiet it was. That was a great idea on the V-bands. I thought of welding those in at the collectors.
Another vote on the Dynomax Super Turbo mufflers. My dually has 1 3/4" long tube Chevelle headers into 3" head pipes w/a H-crossover to the mufflers. I used reducers to go down to 2.5" tailpipes & they exit @ the corners of the bed/bumper.
![]() Join Date: Nov 2018
Where do the pipes exit now? Any exhaust that exits under the truck will rattle your brains out, not to mention when you leave the pavement you look like a helicopter landing.
#8 | |
He ran 4 Chrysler Imperial turbos. Mufflers just like the turbo max. He had room for 4 in a smallish car. Maybe you do to. |
#9 | ||
-did not want them out the back and passing by the fuel tank. -did not want down drafts as my back alley is dirt. (I spend enough time cleaning and polishing this thing.)
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; 11-12-2024 at 03:16 PM. |
Easiest way to quiet an exhaust is to add a crossover. Makes a huge difference.
My vote is for the Dyno Max turbos. Biggest you can fit length wise.
#12 | |
I added an H pipe off long tube 2 1/2 out back through MagnaFlows under bed. It's only loud from the back...in cab noise is not bad. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#13 |
>> had the mufflers under the cab, and out the sides, just in front of the back tires, and it was way quieter.<<
That setup had longer pipes AFTER the muffler. Short pipes after the muffler are always louder. Changing the muffler with the same short pipe and what looks like a megaphone tip will change very little, regardless of the muffler choice. You could consider running the pipes over the axle and out the side behind the tires.
'67 GMC 2500, 292, 4spd, AC |
#14 |
![]() ![]() Join Date: Jul 2002
I liked my Flowmaster Delta 50 series. They were quiet to mild inside, but let you know on the outside they mean business. The ones on my 70 are real quiet, too quiet, but not sure what Generic brand my friend had put on when he had them done 10 years ago.
#15 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
https://www.dynomax.com/catalogsearc...esult/?q=17747
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
#16 |
SpinTech Sportsman XL have a nice note but are not loud
#17 |
![]() Join Date: Mar 2022
Posts 34-35 for me here. I REALLY dig the setup I have. Barks when I want it to, soft & quiet behind the wheel.
https://67-72chevytrucks.com/vboard/...=852752&page=2 |
#18 |
![]() Join Date: Jun 2005
I have Thrush super turbos in 2.5" mounted just behind the cab, tail pipes exit in the stock location behind the rear tires. They are fairly quiet until you mash the pedal. Truck has a mild 402 with 1 3/4 Hedders with 3 inch collectors.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#19 |
Another vote for Dynomax Super Turbos.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#20 | ||
"I ain't nobody, dork."
I've used Flowmaster 40 series on pretty much everything I've ever built. Been using them since they first hit the market and the 40 series was all they made. The difference of running the pipes out the back vs. out the side in front of the tires is a huge difference.
I'm fortunate to have a wife that loves the sound of loud exhaust. ![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#21 |
Do you need 3” pipes? Testing shows until you cross the 600 hp line or so, not any real gain over 2.5”. That will do a lot to reduce the noise level.
On my Camaro I run the 14” case 2.5” DynoMax Super Turbos, and on my trucks I run the 20” case mufflers they used to call the Hemi Turbo muffler. Once again, 2.5” pipe. I’m a big fan of both. Bit of trivia, the Super Turbo is the old Sonic Turbo that was developed by David Vizard and was THEM performance muffler pre-Flowmaster.
#22 |
At the body shop.
If you have the room.
A pair of 70 series keeps my rowdy sbc very quiet
" That didnt make it any newer " " Dont antique the equipment " |
#23 |
![]() Join Date: Dec 1999
Have a single 3" 70 series big block muffler on my 94, good sound and mild. Many compliments. Installing 3" pipes on my 72 project. Dual 70 series with an X-pipe. Will be a tight fit on the shortbed with all that. Still have to wait and see how it goes. I am expecting pleasing results. Will see when I get to the exhaust install.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#24 |
Another vote for Dynomax Super Turbo. I had loud Spintec mufflers, and switched to the dynomax. Much better.
https://youtu.be/O39GYbJp5jM?si=J9oG1QW_kYBVGcWY&t=125
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
#25 |
4th set of mufflers are dynomax super pro (american made). From now on will use nothing else.
1st set was flowmaster 44 then the 50's and 3rd set was something a muffler shop assured me i would like, but no so much. All were 2.5 inch on a small block chevy with headers. |
| Bookmarks |
