What are some good size 15 tires to run on 67-72 C10
What are some good size of 15 inch tires for 67-72 C10?
![]() ![]() Join Date: Apr 2022
Re: What are some good size 15 tires to run on 67-72 C10
Im running 245/60's up front and 275/60s in the rear with my 15x8 rallys on my 68.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
There are several different 15 inch size tires that will work on these trucks. Your best bet is to look at the trucks on this site to get an idea of the look you like.
275/60-15 on 8 inch wheels is a popular choice on a lowered truck. Here is mine. Stock ride height with 31X10.5-15 tires on 8 inch rally wheels.
275/60r15 rear 225/70r15 fronts
I forgot to mention the tires would be for 15x6 steel wheels
![]() Join Date: Jan 2007
I second this ^^^
It’s my favorite size if you’re going for a factory look.
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
A 275 is not recommended for anything under 9 inch but people like myself have them on 8s you end up with a slightly ballooned sidewall. A 6 is way too narrow for that size it’s not recommended for 235s either
This is for an everyday vehicle if you driving a few thousand a year a 235 will work on a 6 inch rim
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 11-23-2024 at 05:19 PM. |
#10 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I like 4 tires the same on my trucks. In the picture with P01 Wheel Covers I had P235/75 15 tires with 15 x 7 rallys and that extra rim inch just ,to me, made the tries look right on the truck. Pink & White truck had 255/70's on 15 x 8 Rally rims and both trucks were stock height. Then I went a bit radical, for me anyway, and lowered the truck witha 2 1/2 dropped spindle up front and 3 inch drop rear spring and added 255/60 17 inch tires on 17 x 8 rims which are within a 1/4 inch of the height of 235/75 15's but the rim stands out and it fills the wheel wells better. If your keeping the truck long term you'll be changing things as time goes by.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
![]() Join Date: Sep 2023
This is mine with 235/75/15s 0n 6 .5 rims
#13 |
![]() Join Date: Oct 2012
Before you buy tires, buy a set of 8inch wheels.
Then you can pull away from a stoplight on wet streets with NO problem. It will make the biggest difference in several ways of traction and handling. Pick up a set of rallys or order some Wheel Vintiques for stock look. Then buy a set of 265's or whatever and you will be happy for years to come. JMHO
Larry 84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles. "It's a sorry man who can't find his wife a good job" Last edited by hooverfish; 11-24-2024 at 01:43 PM. |
#14 |
Back in the 80s I ran 275/60/15 on all 4 corners with manual drum brakes and manual steering on a stock ride height 68 stepper. It was just how I rolled back then. It looked good and worked just fine. YMMV, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#15 |
![]() ![]() Join Date: Jul 2002
235/75 and 255/70 are pretty much the same height, 29 inches. so they will looks somewhat the same from the side. If you want to run the stock 6"wide wheel, I would go with the 235/75. For a 7" or 8 " Id go with the 255/70 They tend to fit the wheel better. 275/60 on 8" wheel looks good, but they are shorter (28"). AS mentioned For all around I like the 255/70 on 8" wheel for a cruiser style truck. If it is going to be used as a truck the 31x10.50x15 on 8" wheels looks great to me, but are way taller than others (31").
| Bookmarks |
