Old 11-29-2024, 04:35 PM   #1
PbFut
72 GMC Hump
Am I misidentifying the hump in my 1972 GMC C25?
I was going to take advantage of the Black Friday sales and order up some parts needed to finish up the fire damage. I started looking for carpet and ACC is not showing an option for a low hump on a 72 GMC. I am 99% sure it's their data base but Rock auto also did not have the low hump option for a 72 GMC. Stock Interiors does show the option on their site for their carpet.
A search seems to show a strong lean to ACC product so I think I will go that direction and order using the Chevy selection.
Can someone confirm this is low hump before I drop a few hundred on the wrong cut?
PbFut is offline   Reply With Quote
Old 11-29-2024, 05:06 PM   #2
LS short box
Re: 72 GMC Hump
Pic of my 68 C10 with a high hump.
LS short box is offline   Reply With Quote
Old 11-29-2024, 05:09 PM   #3
72c20customcamper
72c20customcamper's Avatar
Re: 72 GMC Hump
Aren’t all high humps bolted in as apposed to welded . So I would say low hump
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-29-2024, 05:22 PM   #4
72c20customcamper
Re: 72 GMC Hump
Rockauto has a low hump listed for your truck . They just don’t list the turbo 350 .
https://www.rockauto.com/en/catalog/...,flooring,1264
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-29-2024, 08:14 PM   #5
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Re: 72 GMC Hump
Yeah all high humps are bolted in 67-72. Low Humps are intergrated into the floor pan in 1 piece, its not welded in. Or you could be like me that started with a high hump 4 speed cab and bought a low hump section and reworked it to be a bolt in low hump.
OP has a low hump floor. On ACC select either 3spd manual trans or Auto trans and that is a 2WD, that would be a low hump carpet set.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 11-30-2024, 12:27 AM   #6
PbFut
Re: 72 GMC Hump
Manual trans will have hole in carpet for shifter. Auto 400 is high hump. On the ACC site there is a third option for Chevy and other years, simply Auto for a low hump and no hole as far as I can tell.
Old 11-30-2024, 01:08 AM   #7
pjmoreland
pjmoreland's Avatar
Re: 72 GMC Hump
I don't think a manual carpet would come with the shifter hole pre-cut in it. They leave that for you to do.
pjmoreland is offline   Reply With Quote
Old 11-30-2024, 09:47 AM   #8
72c20customcamper
Re: 72 GMC Hump
Nope . I had to cut the hole for the shifter on my 68its just a high hump carpet for either 4 spd or auto . ACC does not have a 350 listed only the 400 with either high or low hump . OP just needs to order the low hump like I posted
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
