68 K20 rubbing on pitman arm.
I’m curious if this is the correct pitman arm for my 68 k20? Only has 8 inch wide tires on factory rims and it and is rubbing on pitman arm nut. I’ll post some pictures, but everything is factory including closed knuckle axle. Or is it as simple as the axle steering limiter bolt needs to be adjusted? Also worried for when I am going to 10" tires this summer.
1959 GMC 100 3 on the tree 270. 1968 GMC k2500 Stepside 1972 Chevy Monte Carlo Custom. Last edited by 72 k15; 12-17-2024 at 12:44 AM. |
| Bookmarks |
