Old 12-27-2024, 10:32 AM   #1
GM1970s
Junior Member
Help with Fuel Pump wiring/relay
Just picked up this 93 this past couple weeks, finally getting around to it. Has a V6 and stick. It had a stupid alarm system on it integrated into the wiring. That’s all removed now, and noticed starter was bad and replaced as well. Just finally got around to trying to get it to start. I hear the relays go bad on these quite a bit, so I snagged one from a part store to see if anything worked. Nope. Anywho, with a test light, all the junction block wires have power, and also past the plastic links. I noticed no power on the fuel pump fuse on either side. Where do those wires(gray) end up? Does one go to the relay? Possible new relay is bad?
1972 K5 Blazer (Full HICKEY Build)
1971 Cutlass Supreme
1955 Bel Air AG/TLB
GM1970s is offline   Reply With Quote
Old 12-29-2024, 07:38 AM   #2
4u2nv
Re: Help with Fuel Pump wiring/relay
FP relay terminal A (ORG wire):
Should have 10 to 12 Volts DC with Key On Engine Cranking or Key On Engine Running (KOER
Does this help
4u2nv is offline   Reply With Quote
