C30 lift spindles
Im looking lift my 1986 Chevy C30 1ton 2wd truck. Im trying to find lift spindles to make this happen. I currently working with all stock parts.
Re: C30 lift spindles
Do you have a website?
Or know where I can find them? |
![]() Join Date: Mar 2003
I got almost an inch and half lift on my dually just by replacing the front springs. The one tons are hard on them if you use the truck as intended. Mine used to be a class b motor home
Here you go
https://67-72chevytrucks.com/vboard/...d.php?t=447061 If your truck is a dually I’m not sure if you can make this work |
Yes I have a dually set on mine.
Arn't the P30 spindles good for a inch over normal spindles
the best lift spindles are 4x4 leaf spring brackets and a dana 60
| Bookmarks |
