71 C10 Crossmember Identification Help
Good morning.
I'm hoping somebody can help me identify the crossmembers in my 71. I recently removed a 350/350 combo to do some upgrades and cleanup. I realize that was not the stock application. As pictured below, I have labelled 4 crossmembers. 1 = Frame Brace? 2 = Engine crossmember 3 = ? 4 = TH350 transmission crossmember My question is, does crossmember #3 need to stay or was it for a previous manual transmission? I'm hoping to just be able to grind the rivets and remove #3 while leaving the rest in place. I'm staying with a th350 transmission like I removed. If you have a good eye, you will see #3 is torch cut on the right side rear portion where it mounts to the frame. The shift linkage for the th350 was mounted there where its cutout. Thank you |
#2 | |
The Older Generation
Re: 71 C10 Crossmember Identification Help
#3 | |
Always on the hunt...
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
Thanks fellas, appreciate the help.
| Bookmarks |
