Old 01-14-2025, 09:45 AM   #1
bubbasimms
Starting Rust Repair/Difference in Key Parts
Hello All,
Ready to order some rust repair panels. It looks like from reviews Key Parts is currently producing the better parts. Comparing the Key parts Ebay store and prices from Summit. For example, Summit has the lower A pillar piece Part Number: KPT-0849-212R for $18.99. The Key Parts Ebay store has the A pillar listed as Key Parts #0857-212 for $50 plus $11.63 for shipping. What am I missing here? Am I looking at different parts?
Open to any other suggestions. I am doing a full floor replacement, which I already have. I will also need outer rockers, one or both A pillars, one or both B pillars, one or both kick panels and a little bit of the toe board on the drivers side.
bubbasimms is offline   Reply With Quote
Old 01-14-2025, 11:04 AM   #2
PbFut
Re: Starting Rust Repair/Difference in Key Parts
I can not give direct answer but more of a point to be aware of. It appears most of the stamped parts are manufactured by just a couple of companies. There are many who jobber and place the parts in a catalog as their own. It is definitely buyer beware in this area. I tend to think the bigger suppliers like Auto Metal Direct probably vet out the junk simply because they are not going to risk reputation. The hood I received from them via summit racing was produced by TriPlus out of Taiwan. Skeptical when receive, the hood was as good as any oem part. Perfect fit, nice EDP coating. All I had to do was smooth one sharp corner edge, scuff and paint.
PbFut is online now   Reply With Quote
Old 01-14-2025, 11:39 AM   #3
cbeerman
The 0857-212 (Upper image) is a much better and larger version of 0849-212 (Lower image).
0857 (Upper) has the lower door hinge holes with captured nuts. It matches the factory contour of the lower pillar and fender mount. The 0857 also includes the front cab support holes
0849 (Lower) is a simple stamping of the lower pillar area
cbeerman is online now   Reply With Quote
Old 01-14-2025, 11:50 AM   #4
Willshook
I'm starting to order some of these too so I'm super interested. I've been looking at:
https://www.oerparts.com/
https://www.autometaldirect.com/
...then the regular parts places that probably sell these (or other) brands...
Willshook is offline   Reply With Quote
Old 01-15-2025, 03:50 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Here is what I dealt with while installing outer rockers on a '72 GMC. Avoid anything made by Dynacorn. The Key Parts rockers I've used since then have fit pretty dang good without a lot of fab work to get them to fit.
https://67-72chevytrucks.com/vboard/...d.php?t=714835
There are a couple links in that thread that go to my build thread with extra pictures.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-15-2025, 05:10 PM   #6
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Taiwan's better than China anyway. I've got decent parts from LMC.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 01-15-2025, 06:41 PM   #7
KMC3420
KMC3420's Avatar
I like tabco parts, some are made in the USA. You would need to call and ask what is USA made still, but I purchased my cab corners and rockers from them, as well as the A pillar section. All fit nicely. Tabco
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-15-2025, 07:56 PM   #8
dmb
x 2 on lmc I too like LMC panels
dmb is offline   Reply With Quote
