![]() Join Date: Jun 2021
Hood alignment
Done some searching and can't find anything definitive to this problem, so reaching out on our 1972 GMC hood gap.
I think I have validated we have the right year fenders, cowl, and hood (OEM) upper grille, and hood (aftermarket), but I still have this gap. No excessive panel gaps from fender to doors. What advice or measurements do you have to assist with minimizing this gap? |
![]() ![]() Join Date: Jul 2003
You can move it back slightly by loosing the upper hinge bolts. As for the height, the rear rubber seal if hard wont allow the hood to sit flush. Only seal worth a hoot is an NOS GM seal, as they have the correct rubber density, and proper shape.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Re: Hood alignment
If I move it back, then I have a gap up front, which is the premise of the post. There is too much space. Anyone got a link to the OEM hood rubber?
Re: Hood alignment
Can't really tell, but the front edge of the hood, how does it line up with the front edge of the fender?
Re: Hood alignment
![]() Join Date: Nov 2013
Re: Hood alignment
You may have to fudge the cowl forward slightly and the hood back slightly and kinda split the difference. I think the factory tolerance was 3/16" ±.030 so they didn't really fit perfectly from the factory. I had to fudge my hood back about 1/32 but it's not that noticeable.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer .............
![]() ![]() Join Date: Jan 2005
Re: Hood alignment
If you can adjust the doors back, then you can move the entire front clip back, too, which will decrease that hood/cowl gap.
Re: Hood alignment
Thanks for all the suggestions. I will check all of these.
![]() Join Date: Dec 1999
Re: Hood alignment
Looks a little high in the back as well. Loosen the three bolts on each side holding hinges to fenders. Push up on front edge of hood, use a prop rod or have someone hold it while tightening hinge bolts. Should lower back of hood and suck it a bit tighter to cowl.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#10 | |
![]() Join Date: Nov 2018
Re: Hood alignment
It still boggles my mind as to why someone would dismantle a truck to paint it then put the old worn, possibly original cab mounts back on. I took it to a local guy who's been around for years and works wonders on these old vehicles, he did end up moving/adjusting the doors on both sides to get everything to fall into place. |
| Bookmarks |
