Two metal lines running up the back of the cab on passenger side?
I have two lines going from the top of the fuel tank on the passenger side and up the back the cab corner. What are these and where do they go. The lines are held in place with a small bolt clip on the corner of the cab right by the top of the seat. The line were rattling a but against the back of the cab pillar as there is a bit of play in them. I shoved a piece of closed cell foam up there so they cannot rattle.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
