Old 02-17-2025, 10:52 AM   #1
72malibu
72malibu's Avatar
Hood Hinge Color?
I pulled the worn hood hinges off my dad's '75 and they look like original. He doesn't remember them ever being replaced (he's owned it since '76). They are painted black. The truck has had resprays (black truck), so I can't say for sure that the hinges were always black and not the dark gray phosphate color you see on some parts and bolts.
I picked up a pair of new GM hinges (stamped Taiwan 6262007, 6262008) and they are black (appears to be EPD paint).
All signs point to the correct color being black, but I'm not totally convinced and wonder if the original hinges in '75 were phosphate gray.
Any experts in the house?
72malibu is offline   Reply With Quote
Old 02-17-2025, 11:20 AM   #2
S10Fan
Old Heap Driver
Re: Hood Hinge Color?
I found a pair of GM NOS hinges for my square back in '09. They were in GM packaging and were the gray color you mentioned.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-17-2025, 05:13 PM   #3
69Tom
I bought my zinc phosphate from here. Main issue is getting a proper size pan in which to heat them up. But it's doable.
https://www.palmettoenterprisesparkerizing.com/
69Tom is offline   Reply With Quote
Old 02-17-2025, 05:32 PM   #4
Pontiac1976
Pontiac1976's Avatar
I am betting on gray but non painted, kind of gray metal. in the early years I use hate the hinges not matching the inner fenders they all use to rust very fast. But the replacement hinges depending on where they were from and what deal would come black sometimes. spring are none painted. I kind of like the gray now adays would use satin clear to seal them from the air and water. If used, you want to lay it on the dryer side light layers then wetter side.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 02-17-2025, 05:41 PM   #5
Pontiac1976
Keep them greased at the riveted pins both side of the hinge brace for the pair every 4 to 6 months lightly deep into the riveted. And you will never have trouble opening or closing the hood.
