Old 02-17-2025, 05:18 PM   #1
BigElittleg64
BigElittleg64's Avatar
Headers and or manifolds exhaust exit location
Truck is a 1964 C10 Long step lowered. Running 1969 350 and 700r4. Engine is located in the rear position and i have done the 1978 crossmember swap. I have the long tube headers and of course they have clearance issues. I am wanting to run the shorty headers and or smoothed Corvette manifolds with the bigger 2.5" collector. I have been reading all of the headers FAQ's and was wondering if I will have issues with the ones that are straight down, will they come in contact with the crossmember or should i be looking for the ones that exit more to the rear.
BigElittleg64 is offline   Reply With Quote
Old 02-17-2025, 06:42 PM   #2
MikeN
MikeN's Avatar
Re: Headers and or manifolds exhaust exit location
I run the Dorman reproduction 2.5" rams horns on my 64 C10, with the center dump pointing straight down on each side. Works mint - no issues.
MikeN is offline   Reply With Quote
Old 02-17-2025, 07:09 PM   #3
62 Barnfind
62 Barnfind's Avatar
I was stuck deciding if I wanted headers or manifolds. At first I had hooker manifolds but it wouldn’t clear the transmission x member. Ram horns work perfectly and no issues with running exhaust.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 02-17-2025, 07:22 PM   #4
Johnie
Not sure about “rear” position? Mine had the I6 and thats where the mounts stayed. I think the V8 trucks had them further forward so maybe thats what you mean. 2.5 rama horn manifolds work fine on mine. I tried “truck” manifolds that sweep back and those didnt work. Straight down is key
1964 C10 Long Bed Step Side
Johnie is offline   Reply With Quote
Old 02-18-2025, 07:46 AM   #5
cwcarpenter98
cwcarpenter98's Avatar
For the 63-66 trucks, the “rear position” is not applicable. The 230 and 250 inline 6 and 283 and 327 v8s used the same mounting location and frame stands. The 292 of course, had just the different passenger side mount. It wasn’t until the 67-72 trucks where the v8s were moved forward on the frame to allow more clearance between the engine and firewall.
For 63-66 v8s, the center dump manifolds are correct and will have no problems fitting up. If you have moved the engine forward from stock, then you may have some fitment issues
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 02-18-2025, 02:50 PM   #6
BigElittleg64
Great info fella's, just what i was looking for. Much appreciated.
