Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-19-2025, 11:59 AM   #1
red69ss
Burnouts are therapeutic
red69ss's Avatar
starter wiring
I have a new harness from M&H wiring it has a purple and yellow wire going to the starter. the mini starter only has one small post on it , if i put both on the post it starts cranking time i flip the key on, but cranks right with just the purple wire on. my question is what does the yellow wire feed? truck won't start but i'm assuming it's timing
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 02-19-2025, 01:17 PM   #2
RustyPile
RustyPile's Avatar
Re: starter wiring
If you have updated the distributor to an HEI unit, you won't need that yellow wire, remove it from the harness.. A points type ignition system uses a resistor wire between the RUN position on the ignition switch and coil. Its purpose is to lower the supply voltage to the coil. The yellow wire on the "R" terminal on the factory starter solenoid goes to the ignition coil. This wire provides a higher voltage to the coil during the start mode.
If you retain the stock points type distributor along with the mini starter, you can try leaving the yellow wire disconnected.. If you have difficulty with starting the engine, you'll need either a stock starter, OR perhaps (may not be possible) replace the existing solenoid on the mini starter..
RustyPile is offline   Reply With Quote
Old 02-19-2025, 03:06 PM   #3
red69ss
red69ss's Avatar
Re: starter wiring
thanks wasn't sure about it . first time using a mini starter
1969 CHEVELLE SS
