Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old Yesterday, 10:06 PM   #1
IT Cowboy
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Detailing forum here - I cannot do windows
I am just curious there enough interest in a detailing forum here or if the idea has been suggested.
I suck at cleaning windows no matter how hard I try or what products. The best I can do is to use a waffle weave cloth and lots of cleaner. Using a glass stripper has helped me some too. The wand type things with the cloth on the end do not seem to work for me.
On another related note, the magic eraser pads work great on trim and dirty vinyl pieces and even leather seats. My wife used them to clean her 300M seatbelts, dash and door panels and they worked amazing.
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old Yesterday, 11:33 PM   #2
Richard
Re: Detailing forum here - I cannot do windows
There is one already https://67-72chevytrucks.com/vboard/...splay.php?f=65 A sub forum in paint and bodywork
Richard
Old Yesterday, 11:34 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
This is the best I can do....
http://67-72chevytrucks.com/vboard/s...d.php?t=854720
Leon
Old Today, 09:58 AM   #4
Getter-Done
Getter-Done's Avatar
As Richard mentioned there is a Detailing section.
As far as widows go.
To deep clean them start with Vinegar and water.
Then use Windex or Sprayway foaming glass cleaner.
This is what works for me.
A Bit of Info Below:
Vinegar is one of the most effective cleaning solutions for a car window. It works better than soap and will leave your car windows streak free. Just ensure you have the right vinegar to water ratio and use Black and white print newspaper while cleaning to achieve the best results.
Vinegar isn’t necessarily a better cleaner than soap, as it differs from soap. While vinegar breaks through dirt and kills bacteria, it won’t help on filthy surfaces. And you could use a generic glass cleaner like Windex, but you treat the windows of your car different than you treat other windows in your life for a reason.
What is the Correct Vinegar to Water Ratio?
Obviously, you can’t just pour vinegar on your car and call it a day; instead, you need to take the time to make a vinegar solution for proper application.
The proper ratio of vinegar to water when making a cleaning solution is one to one. Therefore, for every one cup of vinegar, you will add one cup of water. Mix both in a spray bottle and apply to your car windows as needed.
Do note that you should never mix anything else into this solution, and vinegar is highly reactive and could react negatively to other cleaning products or soaps.
The early bird gets the worm,
84 Chevy K-20
Old Today, 10:37 AM   #5
IT Cowboy
IT Cowboy's Avatar
Like
I have found Sprayaway at Costco for much cheaper. All of the spray bottle type cleaners are crap these days.
I found the detailing forum finally - thanks
'72 C10 / 402
Old Today, 10:51 AM   #6
Sheepdip
Sheepdip's Avatar
On another note...black and white newsprint is hard to come by nowadays, so I use the old fashioned "Flour Sack" 100% white cotton tea towels sourced through Amazon. Very absorbent and streak/lint free.
Just another option
Sheepdip is offline   Reply With Quote
Old Today, 01:15 PM   #7
Mid-Pack
Mid-Pack's Avatar
Like
So True. Sprayway is the best streak-free cleaner you`ll find.
My .02
Mid-Pack is offline   Reply With Quote
Old Today, 05:51 PM   #8
Sicklajoie
The Niner
Sicklajoie's Avatar
I always use Invisible Glass and a terry towel.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old Today, 06:19 PM   #9
GSP7
GSP7's Avatar
Best thing to was use newspaper to do the wiping. No steaks or cloudy smearing crap
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
