Old 02-23-2025, 05:29 PM   #1
awryexperiment
Antenna Ground Ring
Hi Fellows,
I am wondering if anyone has run across a similar problem where their antenna has developed a wiggle.
My 72 C20 has a fixed mast antenna located in the factory hole (right side of the wiper cowl near the pass door). I removed the cowl and found there's a rectangular soft metal "ground ring" under the sheet metal as part of the mounting bracket.
The problem is that my ground ring developed a crack so it cannot keep the antenna mounted rigidly to the cowl. I haven't been able to find this part reproduced separately, so I would need to buy a whole new antenna kit.
Has anyone had a similar problem? Was there any way to fix the problem without replacing he entire antenna?
thanks.
awryexperiment is offline   Reply With Quote
