Old 02-26-2025, 07:25 PM   #1
Artie Sellars
1964 GMC 1000 axle flip kit
I’ve been lurking around here forever and I can usually find what I need just by researching this site. However, I can’t seem to find anything about this. Does anyone have a source for an axle flip kit for a 1964 GMC? Plenty of stuff for Chevrolets but nothing for the GMC’s with leaf spring rear ends.
Artie Sellars is offline   Reply With Quote
Old 02-26-2025, 09:25 PM   #2
karlbenz
Re: 1964 GMC 1000 axle flip kit
good luck. Not a lot out there for GMC specific stuff
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 03-02-2025, 11:10 AM   #3
cwcarpenter98
cwcarpenter98's Avatar
Take some measurements to verify, but you may be able to use an axle flip kit for a squarebody. If your axle tube diameter is the same as a truck 12 bolt from the 70s, and the leaf spring width is the same, in theory, it should work
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 03-02-2025, 12:43 PM   #4
SCOTI
SCOTI's Avatar
Pre-73 GM truck leafs were narrower (2.25 vs. 2.5") IIRC. A later model flip kit might require some trimming or tweaking but could provide some useful parts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-03-2025, 07:58 PM   #5
PapaJbbq
The squarebody frame is taller and narrower than the Gen 1 frame, A flip kit for one won't work for the other.
Get some 1/4 x 4" flat bar and build your own.
PapaJbbq is offline   Reply With Quote
Old 03-04-2025, 10:48 AM   #6
SCOTI
SCOTI's Avatar
I'm curious.... How does the frame rail differences between the two eras have an impact w/the flip kit method of lowering?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-05-2025, 01:24 PM   #7
PapaJbbq
I was referring to installing a C-notch. I neglected to mention my 66 GMC will need a notch to flip the axle, because I'll get a 5" drop, but only have about 2" of travel before the flipped axle hits the frame.
The C-notch method will be the same between generations, but the frame dimensions are different. So, pre-cut pieces for a squarebody will not fit the frame of a 60-65.
Sorry for the incomplete information.
Here's something that might be useful:
76 C10 12-bolt axle tube dia = 3"
Spring width = 2-1/2"
66 Dana 44 axle Tube dia = 2-5/8"
Spring width = 2-3/8"
Old 03-06-2025, 12:14 PM   #8
SCOTI
SCOTI's Avatar
Gotcha.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-10-2025, 02:25 PM   #9
Slammed96
Sorry for the late reply to the thread, but I actually have a flip kit that will fit your truck that I'd be willing to let go. I wound up flipping my spring perches and re welding them on my setup. Only thing that's missing from the kit is the u bolts, but those are pretty easy to come by. Also in reference to your notch question, a 64-66 c10 notch kit should work fine for you. I used that generation step notch on mine and it works great.
14 Silverado- 4/6 drop daily
66 GMC short wide Custom Cab- building to be low and cruise. 283/t56 swap occurring now. Stupid low static drop
55.5 Chevy 3600 NAPCO 4X4.... not sure where I'll take this one...
Slammed96 is offline   Reply With Quote
