Old 02-26-2025, 11:49 PM   #1
kwmech
SPID help
Putting info together to have a spid made for my GMC. I cannot find any designation regarding a 157'' wheelbase. Any help?
Old 02-27-2025, 01:33 AM   #2
402Bowtie
402Bowtie's Avatar
Re: SPID help
What year gmc?
On the spid, I think you would see reference to 157" in two spots:
1) the "w/base" entry at top of spid
2) the model number. Specifically, I think you would see "64" in the sequence which correlates to 157" wheelbase.
See the attached pic for an example (69 gmc found here). Also, here is a reference point for model numbers... While it doesn't call out 157" wheelbase I think you have enough info to put the pieces together.
402Bowtie is offline   Reply With Quote
Old 02-27-2025, 03:10 AM   #3
kwmech
Re: SPID help
Thanks, that helps. I see by that vin that truck has the V6. Mine used to be a Class B motor home with quite a few options involved. The coach part of it was all rotted with water damage and cut off the frame
Old 03-03-2025, 07:45 PM   #4
cbeerman
Re: SPID help
Here is your model number from the GMC parts book
CM3640V
cbeerman is online now   Reply With Quote
Old 04-23-2025, 03:07 PM   #5
John_Stewart
New Member
John_Stewart's Avatar
Re: SPID help
Originally Posted by 402Bowtie View Post
What year gmc?
May be a stupid question, ..... I know what my V.I.N. is, W/Base: 127 IN, ........... but what does the SE mean? Mine says: FT0979401
John_Stewart is offline   Reply With Quote
Old 04-23-2025, 05:14 PM   #6
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: SPID help
SE: Special Equipment
Old 04-23-2025, 06:10 PM   #7
John_Stewart
New Member
Re: SPID help
Thank You
Old 04-24-2025, 10:56 AM   #8
HO455
HO455's Avatar
Re: SPID help
Caution hijack imminent!
Just out of curiosity which dash bezel did your class B have in it?
I put one out of a class B into my Burban. The camper only had 8710 miles on it when it was caught in a flood. It then sat in a barn for 45 years slowly rotting away. I got an almost perfect set of guages from it. They however are a bit odd in that they are a brownish gray color with no chrome that I've never seen before. I've wondered if it was a cab chassis thing.
Is yours similar?
RIP Bob Parks.
Old 04-24-2025, 11:59 AM   #9
kwmech
Re: SPID help
It had the normal bezel for a GMC. I put in the tach dash. One thing that was odd was the t400 did not have a parking pawl or linkage. Nor did the steering column. I had a R N D L L2. That has since been changed also. The truck being a class B had lots of additional stuff though like camper package with heavy suspension, dual battery, HD alternator etc
Old 04-24-2025, 02:13 PM   #10
Getter-Done
Getter-Done's Avatar
Re: SPID help
Are you letting Jeff fix your SPID? (outintheshop)
The early bird gets the worm,
85 Chevy K-20
Old 04-24-2025, 03:24 PM   #11
CG
BlahBlahBlah
Re: SPID help
Here is the spid off of my 71 Chevy C30 ex motor home, also a 157 in. wheel base. No idea if this is any help for you.
Old 04-25-2025, 05:33 PM   #12
HO455
HO455's Avatar
Re: SPID help
Thanks. My mystery continues to be a mystery.
I wonder if GM didn't think the parking pawl was up to the possible load that could be imposed on it with a fully loaded camper and deleted it to dodge any possible liability issue if one were to fail.
RIP Bob Parks.
