Old 03-08-2025, 08:37 PM   #1
JD'S 69
JD'S 69's Avatar
1969 chevy truck engine move forward.
Not sure if this is the right spot to ask questions. Has anyone removed the rivets on the trans cross member and moved it forward about 1 inch. Is this possible, I know the engine mounts could be moved but trans cross member might be tricky.
I have attached some photos, not sure if I'm doing this correct.
Thanks Jeron
When I stand before god at the at the end of my life, I would hope that I would not have a single bit of talent left, and I could say," I used everything you gave me"
My 69 stepper http://67-72chevytrucks.com/vboard/s...d.php?t=601095
JD'S 69 is offline   Reply With Quote
Old 03-08-2025, 11:49 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1969 chevy truck engine move forward.
Thanks Jeron
I have never tried it but you should be able to. 1" isn't all that far. What is the problem you are running into? You would have to move the clutch z-bar bracket on the frame and lengthen the clutch linkage rod too.
Leon
Old 03-09-2025, 07:35 AM   #3
They can be done, much easier with body off.
with what LockDoc said though.
Old 03-09-2025, 08:25 AM   #4
Mickeymotormount
Mickeymotormount's Avatar
You have to measure the distance from the rear set of engine mount bracket holes to set of holes your brackets are in now. Whatever that distance is, the crossmember must also move forward.
Not quite sure if the same crossmember will work since it is moving upward into the frame. The bends on the crossmember ends may not work exactly in the new location. You may have to search for a true V-8 crossmember which came in the forward set of holes from the factory.
John
1967 C20 2WD Longbed
2001 2500 HD 4X4 Extended cab long bed
Mickeymotormount is offline   Reply With Quote
Old 03-09-2025, 09:33 AM   #5
HalfBrit
Since the frame rises in that area, it seems like you would be changing your engine angle as well (raising the rear of the transmission). Just a thought. If you're going to the trouble of removing it you could just install a "regular" crossmember that supports the transmission tail shaft. That would give you the most engine location flexibility.
HalfBrit is offline   Reply With Quote
Old 03-09-2025, 11:07 AM   #6
JD'S 69
JD'S 69's Avatar
I have very little clearance from distributor to fire wall.
Old 03-09-2025, 11:08 AM   #7
JD'S 69
JD'S 69's Avatar
Thanks I will look at cross members.
Old 03-09-2025, 11:31 AM   #8
LockDoc
LockDoc's Avatar
Here is a thread where I posted the difference between the I6 and V8 cross members and where they are mounted. The holes are there for both of them....
http://67-72chevytrucks.com/vboard/s....php?p=9145757
Like Mickey mentioned your best bet would probably be to source a v8 cross member.
Leon
