Old 03-20-2025, 01:58 PM   #1
chris989
Did new door latches solve anything?
Hello all,
1989 v2500
After paint I installed new weather stripping and Like 99% of all weather stripping it is to stiff.
My doors shut decent before,, not perfect, but now have to be slammed with follow through. I readjusted, they actually sit a little high but still suck to close.
My latches operate as designed but are ~35 years old. Has anyone installed the new latched,, like from brothers trucks and noticed any appreciable latching qualities?
Thanks in advance
Chris
chris989 is offline   Reply With Quote
Old 03-20-2025, 11:01 PM   #2
Shark_13
Re: Did new door latches solve anything?
I'm curious too. I did the same, new seals, and really have to slam to fully close.
Old 03-21-2025, 07:23 AM   #3
chrismoore701
chrismoore701's Avatar
It will take a good year or two to get the doors to close better, the weather stripping needs to get compressed. it will be fine. I used all my old hardware on my 79 build, close fine now
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-21-2025, 08:32 AM   #4
Bloodhound
I did all new seals on mine when I did paint. Definitely takes quite a while for them to break in. The other key thing is make sure you have the bushing on the door striker, I did the very effective piece of PEX pipe as a bushing, makes a huge difference in the ease of door closing.
https://67-72chevytrucks.com/vboard/...hlight=striker
Bloodhound is offline   Reply With Quote
Old 03-21-2025, 11:53 AM   #5
chris989
Thanks for the replies,,
I get the waiting,,, but that is a band aid. I found NOS barn door weather stripping and it is noticeably softer, more pliable and the thinner. Night and day difference.
My wife drives an 2002 burb, here door weather stripping is defiantly softer than my aftermarket. I went to the junk yard yesterday and pulled a complete door stripping from an 02 denali.
I am going to remove my aftermarket stripping, adjust the door as best i can and install the newer OEM stuff.
If it works better, I am hoping to purchase the newer stuff OE. I buy pvc/rubber for other businesses and companies like Trimflex make/sell generic weather stripping.. I believe all of these retailer are just buying off the self stuff, cutting it to lenght and selling it as a replacement.
Here is an example,
https://www.camperid.com/ap-products...437871059.html
Old 03-21-2025, 11:56 AM   #6
chris989
I think Precision sell stuff just like this,, NOT a GM spec
Old 03-21-2025, 11:58 AM   #7
chris989
Here is one with a 3/8 bulb
Old 03-21-2025, 12:12 PM   #8
chris989
Here is a good source,, I will request more data, get samples and report back.
https://mmseals.com/collections/car-door-seal
But back to the latches,,, Anyone install a new latch and find it better or worse?
Smoother, quieter?
Chris
Old 03-21-2025, 02:32 PM   #9
Dead Parrot
Not sure if yours still has the plastic bushing around the striker bolt but simply replacing that made a big difference in how the doors on my 75 C10 and 84 CUCV seal up.
Dead Parrot is offline   Reply With Quote
Old 03-21-2025, 02:37 PM   #10
chris989
I have it,, all new
The doors shut ok, I notice it is the rubber compressing near the hinges causing the most issue... I can hear feel the resistance before the door comes close to reaching the stricker
Old 03-22-2025, 09:54 AM   #11
72c20customcamper
72c20customcamper's Avatar
Did you leave a space where the rubber meets up on the rocker panel lip ? I’ve seen people make everything nice and tight and then have trouble closing the door .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
