Old 03-24-2025, 03:16 PM   #1
epfatboy
20” wheels to 15” wheels
Yep, 20” to 15” is the direction I’d like to go.
Want to do this on a 1974 C10 short bed step side. Truck has a 4” drop.
Current sneakers are 275/40R20 front and 315/30R20 rear, no rubbing. Mounted on 5x5 Riddler rims..
WITH UNKNOWN Backspace.
Anyone have some experience with what fits my combo in terms of a 15 (ish) rim, I assume a 15/10 5x5, really looking for BS (or offset) and what rubber your running on a step side.
I’m buying new so I have some option, like I might not hate the idea of a 16 or 17” rim but I do like a meaty sidewall.
I can measure, and will, just being lazy and want to window shop.
epfatboy is offline   Reply With Quote
Old 03-24-2025, 08:15 PM   #2
raggedjim
raggedjim's Avatar
Re: 20” wheels to 15” wheels
Lots of choices from this thread...
https://67-72chevytrucks.com/vboard/...d.php?t=703601
raggedjim is offline   Reply With Quote
Old 03-28-2025, 01:32 PM   #3
Loco83
Loco83's Avatar
15x8 and 4" BS and 15x10 with 5" BS, 245/60/15"s and 295 /50/15's.
Loco83 is offline   Reply With Quote
Old 03-28-2025, 05:38 PM   #4
epfatboy
Loco,
You’re the man, that’s what I needed. Those look nice in there.
Should mention (and research) I’m running rear disc with eldo calipers pretty sure they fit 15” rims….
Old 03-28-2025, 06:02 PM   #5
72c20customcamper
72c20customcamper's Avatar
Originally Posted by epfatboy View Post
Loco,
I have the same setup on my Chevelle on the rear no problems with 15” inch rims .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-28-2025, 06:13 PM   #6
epfatboy
Research disc caliper to 15" rim fitment... CHECK. Thanks for that.
Old 04-05-2025, 12:33 PM   #7
Richard D
Richard D's Avatar
Perfect, the front is just a tiny bit shorter than the rear. I had custom truck rallys 15x10 with 5" backspace years ago, does anyone make them off the shelf?
Richard D is offline   Reply With Quote
Old 04-05-2025, 06:40 PM   #8
v30crewcab
v30crewcab's Avatar
what spindles do you have? 15" don't like 3" drop spindles.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-05-2025, 09:17 PM   #9
epfatboy
Not a great pic (as of today, I’m behind nothing new) but it shows the 20” wheels I’m looking to replace. Tires are 315/30R20 (27.4” tall) and 275/40R20 (28.6”).
I like the idea of 15” with:
295/60R15 ( 28.9) and 245/70R15 ( 28.4)
Little more height tire won’t hurt (4L80e/3.73) and I’ll like the extra sidewall.
I have a 2” spindle/2” spring drop front and an axle over rear.
Old 04-08-2025, 10:38 AM   #10
SCOTI
SCOTI's Avatar
Standard truck ralleys are always a good choice for Squarebody trucks....
Front: 15x6.5" Van ralley; 215/75-15 tire @ 27.7"
Rear: 15x8.0" Truck ralley; 255/70-15 tire @ 29"
88-98 15" OE trim rings
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
