Old 04-07-2025, 12:58 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Removing the crank shaft pulley.
Is it just the 3 bolts + the one in the middle? No puller or any other tool needed?
desert-rat is offline   Reply With Quote
Old 04-07-2025, 02:19 PM   #2
Roostre
Roostre's Avatar
Re: Removing the crank shaft pulley.
I believe the pulleys come off as you describe. If you are removing the harmonic balancer, you'll want a puller as it's two pieces held together with rubber and you'll pull it apart if you pull on the outside of it.
Roostre is offline   Reply With Quote
Old 04-07-2025, 07:31 PM   #3
truckster
truckster's Avatar
The three bolts attach the pulley to the harmonic balancer. The harmonic balancer is held on by the single bolt in the middle. Remove the pulley, and use the three outer holes to attach the puller.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
