Old 05-05-2025, 07:08 PM   #1
Orefactory4x4 swb
Wiring problems
Hello, just finished up my new aaw
harness.
Couple problems. Fist brake light in dash stays on unless unplugged from new master.
2nd.. front marker lights come on with brakes pushed
Any feedback appreciated
Orefactory4x4 swb is offline   Reply With Quote
Old 05-05-2025, 07:37 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Wiring problems
The brake light sounds like the switch is grounded . Try a continuity test on it .
The front markers could be a problem with the turn signal switch
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-05-2025, 08:14 PM   #3
Orefactory4x4 swb
Re: Wiring problems
Appreciate reply
I bought the new rebuilt tilt off a member, maybe I’ll give him a pm and see if he can think of anything.
Old 05-05-2025, 08:45 PM   #4
Orefactory4x4 swb
Re: Wiring problems
I think you’re on to something.
I went out and looked. If you push in the emergency flashers. They don’t work until you turn the blinker on. And front marker lights come on to when breaking.
Turn flasher off, everything works fine.
Old 05-06-2025, 02:38 PM   #5
Classic Bowties
Always on the hunt...
Re: Wiring problems
After completion of your diagnostic check and if a replacement switch is needed, we have the long discontinued GM NOS tilt column specific turn signal switch and harness available in the below linked parts board F/S thread, the t/s switch is listed as item #16 on the NOS parts list. Let us know if interested, Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=798288
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 05-06-2025, 06:12 PM   #6
Orefactory4x4 swb
Re: Wiring problems
Thanks Mel
It’s all new stuff in the column so I’m hoping I luck out with something else I’m missing, if not I’ll be calling.
Old 05-06-2025, 06:20 PM   #7
PbFut
Re: Wiring problems
Re brake light. It is very likely the combo valve got tripped while bleeding the brakes. So your brakes are only working on one circuit. Likely front. You need to reset combo valve, lock the shuttle valve in the center position and bleed brakes with lock tool holding shuttle valve. Then reinstall brake warning switch on combo valve.
PbFut is offline   Reply With Quote
Old 05-06-2025, 08:26 PM   #8
Orefactory4x4 swb
Re: Wiring problems
You lost me, but appreciate your help
I’ll research what you replied.
What’s a lock tool.?
Old 05-06-2025, 08:58 PM   #9
Orefactory4x4 swb
Re: Wiring problems
I ordered that little tool
I’ll let you know what happens, but I think you’re right. I did the fronts , then the backs a few weeks later.
I think that’s what it is.
Old 05-07-2025, 07:08 PM   #10
Orefactory4x4 swb
Re: Wiring problems
You were right on the switch being tripped bleeding brakes
Thanks for the help
Old 05-07-2025, 07:12 PM   #11
Orefactory4x4 swb
Re: Wiring problems
You nailed it, the switch was grounded out. I ordered the little tool, but took it off and moved it back with a pointed testing light. Lights off…
Thanks for the help… I already started getting grey hair, and these problems don’t help.
Old 05-08-2025, 07:29 PM   #12
Orefactory4x4 swb
Re: Wiring problems
Member reached out to me thinking it the switch, and willing to send new one,
Or send column back for repair.. better service than any commercial seller.
Must appreciate Don D…
Old 05-09-2025, 01:20 PM   #13
PbFut
Re: Wiring problems
It's when you start loosing your hair from pulling it out you need to worry. Glad the brake light solution was simple.
