Old 07-15-2025, 01:56 PM   #1
Chaparralman1974
Chaparralman1974's Avatar
Brake Booster Question
Morning gang,
Now that I have been able to finally start moving my truck around, I am finding that I would like a little more stopping power. My K20 is all stock with a drum/drum setup and manual brakes. Everything is brand new including the master cylinder. Can I just add a brake booster to my setup, or do I have to replace the master cylinder as well?
Thanks, Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20 "The Town Truck"
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 07-18-2025, 08:36 AM   #2
custom10nut
custom10nut's Avatar
Re: Brake Booster Question
Originally Posted by Chaparralman1974 View Post
Morning gang,
Thanks, Clay
If we were closer (I’m in East Tennessee), I have everything you need.
I just installed a CPP Disc Brake Conversion on my 70 C-10 (Highly recommended if you’re gonna be driving the truck much), and have all the Drum/Drum Hardware in a box.
To convert you current system to power you’ll need the following:
A longer (Adjustable) Actuator Rod
The firewall brackets and support braces (you have to look for these, because to my knowledge, there are no aftermarket ones made)
The Vacuum booster (I used the factory Delco model)
The rest of your current setup can stay in place.
You’ll have to carefully stretch your brake lines a little bit but there’s plenty of to wok with (or you can replace it, your choice)
custom10nut is offline   Reply With Quote
Old 07-18-2025, 08:11 PM   #3
RichardJ
Your manual brake MC should have a deep hole in the back of the piston. CPP sells their MC with a plug so that their MC can be used with a booster or without.
Ebay sells the plug but calls it a bullet.
You still have to adjust the pin on the front of the booster for correct length.
https://www.ebay.com/itm/285163430346
Link doesn't seem to work. Here is a screen capture.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-18-2025, 10:49 PM   #4
Chaparralman1974
Thanks fellas! I actually found a guy here on the forums that builds a complete booster kit for our trucks that are all adjusted and ready to bolt on. I gave him a call and he is getting one built up for me.
Clay
Clayton Sikes
Peoria, Arizona
