Old 07-19-2025, 01:54 PM   #1
AussieinNC
Moderator
AussieinNC's Avatar
LS series Knock Sensors relocation pieces
This is an FYI post not a for sale or commission item....
I have found the following items that anyone with an LS series 3 engine that has knock sensor issues.
These will allow the relocation of the knock sensors away from under the intake manifold and make servicing the sensors so much easier.
The items are a set of billet brackets that bolt to the pan rails of the LS engine plus a new wiring loom that will replace reach down each side of the engine to the bracket locations.
The wiring loom connector for the knock sensors in drivers side rear of manifold...simple single plug GM style.
The loom is
https://www.amazon.com/dp/B084KP8VYB...fed_asin_title
The bracket kit is
https://www.amazon.com/dp/B0D3LPLNKG...fed_asin_title
I am going to fit these onto my daily driver...after 260,000 miles the rear knock sensor has died...and me getting old now I am always looking to make things easier....
Just thought I would share.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 07-23-2025, 04:37 PM   #2
cj847
cj847's Avatar
Re: LS series Knock Sensors relocation pieces
Interesting. I've always wondered what people were using to move the knock sensors on a gen 3. I know that most drill and tap the block when using a gen 4 block with gen 3 crank and wiring harness. Let us know how well they work.
cj847 is offline   Reply With Quote
Old 07-24-2025, 07:50 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
They were a bit of a fiddle to install...like maybe 15 mins a side.
Standard sensors go into the blocks and wire loom plugs directly into the factory fitting.
Codes went away immediately.
2025 Chevy Equinox
Old 07-25-2025, 02:46 PM   #4
leegreen
those would take the sting out of having a new sensor under the intake start throwing codes after 2 weeks
leegreen is offline   Reply With Quote
Old 07-31-2025, 09:43 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
Just dont fall for the el cheapo Amazon knock off knock sensors...use the Delphi ones and you will be good...
Heck, my original knock sensors lasted 270,000 miles....
2025 Chevy Equinox
