DBW Pedal. How to get the right ergonomics?
Yup. Still Alive and still plugging away at Woody - life has definitely got in the way of play hence the delay.
Anyway... I have my 07 Silverado DBW pedal mounted to the original throttle pedal holes in the firewall and bent the pedal so it is now in the right plane - challenge is that the pedal is too high. Now before I go all cave man, cut a wedge out of the pedal, bend and weld how have others created the ultimate throttle to brake pedal ratio? Read the various threads and seen the awesome fabrication but:- 1. Dont want to spend $100 plus shipping for a bent bit of steel - not taking anything away from anybody but seems a tad expensive. 2. Dont really want to be welding close to the sensors as that seems like a great way to throw a code. So, fellow cave men, how did you do it? Edit Just found this which is probably cave man engineering at its best but seems to work! https://youtu.be/IwPgqszKjdc?si=a0lx9BOiGV0xvLFs P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... Last edited by Paul Y; 08-12-2025 at 01:54 PM. |
| Bookmarks |
