Old 09-06-2025, 09:00 PM   #1
guyryan100
guyryan100's Avatar
Switching serpentine to old school brackets
Hi,
The only accessories I have are a water pump and alternator. I have a serpentine bracket set but it just a bunch of blank pullies, turning only the water pump and alternator. I'd like to switch to standard brackets but having trouble finding what I need. I currently have a long water pump and a small case alternator. I think I'll have to change my water pump because its a counter-clockwise pump and has no posts for bolting accessories.
Does anyone know what bracket I could use for the alternator, and with a new long water pump? Or do I need to change to a short water pump? The brackets I find online don't always specify if they are for the smaller or larger alternators or what pump they are compatible with.
I also realize I will need different pullies.
Thanks for any ideas!
guyryan100 is offline   Reply With Quote
Old 09-06-2025, 09:22 PM   #2
franken
Re: Switching serpentine to old school brackets
I'd first ask if your heads have threaded bosses/holes for accessories. If so, you have later heads.
franken is online now   Reply With Quote
Old 09-07-2025, 03:57 AM   #3
lil hoodlum
lil hoodlum's Avatar
The 1973+ small blocks used the long water pump. The alternator is also mounted on the passenger side. I believe the alternator bracket for the 73-1987 is the same for the small block chevy.
I thought the standard rotation of the pulleys was clockwise, but believe it changed to counter clockwise later on. Not sure on any of the dates for the change overs.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 09-07-2025, 12:08 PM   #4
kwmech
Just about any Chevy car or truck with a small block from 73-86 should work. Alt will be on the pass side though. Or if you want to stay within the year correct set-up, then you'll be back onto the short water pump and limited to the earlier years ending in 72 with the alt on the drivers side
Old 09-07-2025, 12:15 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Alan Grove makes a nice alternator bracket. Bolts on water pump and hangs low and out of the way.
https://www.alangrovecomponents.com/..._Long_Pump.htm
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
