Old 09-10-2025, 10:09 AM   #1
CJ2A
CJ2A's Avatar
Convert Mechanical Clutch to Hydraulic
Has anyone successfully converted a mechanical clutch linkage to a hydraulic system ?
I am wanting to use a stock bell housing with a slave cylinder. Does anyone know of a kit that offers a slave cylinder and mounting bracket that aligns up with the stock bellhousing & clutch fork ?
48 CJ2A
63 1500 GMC (LS1 w/ Muncie 4spd)
68 RS Camaro
71 K20 BBC & granny 4 speed
95 2500 4x4
17 HD2500 4x4
Want => 67 C10 short bed w/ Manual Tranny
CJ2A is offline   Reply With Quote
Old 09-10-2025, 01:20 PM   #2
scottofksu
scottofksu's Avatar
Re: Convert Mechanical Clutch to Hydraulic
I am in the process of doing so for my '65! All I needed was a Captain Fab brake booster bracket that has the provisions for a clutch master cylinder similar to the arrangement of early 60's trucks. I then got a Wilwood master and slave combo that will work with my '94 T56 I'm installing.
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 09-11-2025, 12:56 AM   #3
Rocky1962
New Member
Rocky1962's Avatar
I figure you would have to use the 60-62 bellhousing with cylinder and fork. Then get the rest of the firewall stuff from the mighty Captain Fab
Rocky1962 is offline   Reply With Quote
Old 09-11-2025, 09:34 AM   #4
CJ2A
CJ2A's Avatar
Yes, Original bell housing.
Need slave cylinder with a slave cylinder bracket that align the slave cylinder and clutch fork up correctly
48 CJ2A
68 RS Camaro
95 2500 4x4
17 HD2500 4x4
Old 09-11-2025, 03:01 PM   #5
Paul Y
I used these guys when I converted my 56 Pu to a hydraulic clutch set up.
Would recommend.
https://www.novak-adapt.com/catalog/...r-gateway.html
You will need to get a master cylinder and make sure that the firewall is strengthened but this was simple and effective.
Let us know how you get on.
Paul
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 09-20-2025, 08:26 AM   #6
CJ2A
CJ2A's Avatar
This is going to work
Thank You !
48 CJ2A
68 RS Camaro
95 2500 4x4
17 HD2500 4x4
Old 09-24-2025, 11:48 PM   #7
R_W
R_W's Avatar
American Powertrain sells a hydraulic throwout bearing. I have been using one for a couple of years with a T56 in another car.
https://americanpowertrain.com/shop/...L6LeWHtY6L4pka
______________________
"Daddy, that truck's not red"
Build Thread: TN 20 Build
R_W is offline   Reply With Quote
