Old 09-28-2025, 07:47 PM   #1
FatherandSon
Best/easiest connection to 69 C20 dash lights circuit
I purchased a new Antique Automobile Radio unit for my 69 C20 to replace my 10 year old malfunctioning Custom Auto sound unit. The wiring is the same except the new unit has an extra power wire to power a dial light when the headlights are turned on. Has anyone installed one of these? What's the easiest place to connect?
FatherandSon is offline   Reply With Quote
Old 09-28-2025, 09:29 PM   #2
Richard
Re: Best/easiest connection to 69 C20 dash lights circuit
If you have a stock fuse panel there should be a tab labeled CLSTR
Richard
Old 09-28-2025, 11:01 PM   #3
FatherandSon
Thanks Richard! I considered connecting there but wonÂ’t that send power to the dial light anytime the ignition is turned on or to accessory rather than when dash lights/headlamps are on?
Old 09-28-2025, 11:41 PM   #4
Richard
That terminal is only hot when park or full lights are on. I used it for the tilt column light. You can verify yourself with a DMM.
Richard
Old 09-28-2025, 11:58 PM   #5
truckster
truckster's Avatar
If I remember correctly, there's also a gray wire that goes to the light on the heater control. That would be right below your radio.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 09-29-2025, 11:09 AM   #6
FatherandSon
Thanks Richard and Truckster! My truck has factory AC, so the CLSTR tab will actually be the easiest part of the install!
Old 09-29-2025, 12:32 PM   #7
FatherandSon
antique automobile radio
