Old 10-08-2025, 02:56 PM   #1
GreyFox
GreyFox's Avatar
65-C20 Assembly question
Getting started on reassembly and the rear axle seems off after I attached the springs to the Trailing Arms. Is there a particular position for the spring to be attached to the frame or the Trailing Arm?
Look closely at the springs - They seem like the Left one (Top Picture) is looking more tilted toward the left and the Right one seems a little tilted to the left.
Do you see the tilt?
Should I make they look more Vertical?
Let me know,
John
GreyFox is offline   Reply With Quote
c20 2wd fleetside, eaton ho52, long bed
