Old 10-13-2025, 10:20 AM   #1
D13
D13's Avatar
292 4wd crossmemeber image
Some time ago there was a discussion on 4x4's with 292 sixes using a unique cross member. As I was rearranging my piles yesterday, I dug out a sample of both. You can see the 292 version (on top) has a z shape to it that positions the RH frame perch forward (left in the image), as compared to the V8 version (on the bottom). My current assumption is the 250 uses the V8 crossmember with the mounts moved, although I have never seen a 250 powered 4x4 in person to prove this out. This should be good for both 1/2 and regular 3/4 tons as they use the same frame for 4x4. Anyone have a heavy frame K20 or a K30 4x4 with a 292 so we can get a look at those crossmembers?
These are quite rare (it took me 2 years to find one), and I know Backpayne was looking for a looong time.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
292 k10 k20 4x4 4wd
