Old 10-26-2025, 04:35 PM   #1
brandnew72
BagRiders Pro Manifold/Controller Review
Original air ride install was an EZ Air Ride 4 corner, paddle valve setup. Very functional but was looking for a more intuitive control system. Bagriders shipped very quick. I had the setup at my door in about 4 days.
BagRiders Pro setup comes with the manifold, 2 wiring harnesses, most fittings you'll need, handheld controller with phone app and a variety of extra pieces and parts to get you through the install. If you are installing from static and using the water trap, you will want a couple extra PTC fittings to connect everything. If you're upgrading from the EZ Air Ride, you can reuse the straight PTC from the Tee fitting. I also added the water trap and manifold mount.
The wiring harness is very nice. Its clean, labeled, loomed and comes with some shrink wrap that's labeled as well. I shortened some of the wiring since my battery is in the bed. The harness has PLENTY of cable.
Wiring everything up is straightforward. The diagram they include is very clear and has additional wiring options for a 2nd compressor included in the layout.
The controller cable is quite long and connects from the manifold harness and you can run it to anywhere in the cab. My old system had a manual switch to cutoff the compressor in case of an issue. This setup has autostart on ignition and you can set the PSI settings for the compressor to run and shutoff. The system won't cycle the compressor or the controller unless the ignition is keyed on or in ACC.
There are a ton of servings that are adjustable.
- Air out on shutoff
- Air up on cranking
- 3 height adjustable presets plus an Air Out preset
- 4 corner exact PSI visualized in the controller
- locked controller so no accidental air release
And there are more settings in the controller as well as a tank pressure display and voltage display.
All in all, I was hesitant to order due to lack of reviews, compared to the Airlift setups. I know time will tell and hopefully won't need customer service for a bit, lol. But initial impressions are very good.
brandnew72 is offline   Reply With Quote
