Old 11-05-2025, 02:22 PM   #1
Daron Craig
65 Big Block Swap Question
Hey guys,
I know the 68-71 big block brackets are good to use for the swap. As far as the motor mounts. I'm looking on autozone website and a I see the duralast 2283, but it doesn't look like it has a bushing. I guess I'm asking is there a part number you guys know of that has both? Or a link to a set of them that will work? Thanks in advance.
Daron Craig is offline   Reply With Quote
Old 11-06-2025, 10:59 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: 65 Big Block Swap Question
I used these for my BB swap. Just do a search for tubular motor mounts. They don't seem to be tubular anymore. I used these because they were the only ones I could get to clear the headers. You do have to trim the upper frame a bit. I believe you can see it in this picture. These have been working in my truck for over 10 years.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-06-2025, 05:27 PM   #3
Daron Craig
Thanks for the info bud. What headers did you use? I’m going to be looking for those as well.
Old 11-08-2025, 10:43 AM   #4
Chevy Fleetside
Those are Hedman Elites. I made the mistake of using long tube headers. You should use 3/4 headers. Long tubes hang down to low.
Old 11-08-2025, 11:01 AM   #5
Daron Craig
Do you recall the part number or application you searched for?
Old 11-09-2025, 10:51 AM   #6
Chevy Fleetside
I just did a 70's chevy truck. Most guys were using headers for chevelle's. 3/4 headers
Old 11-09-2025, 01:31 PM   #7
Daron Craig
That is what I figured. I found the mounts from POL. You were right, they aren’t tubular anymore, but they do allow the use of Chevelle, nova, Camaro big block motor mounts.
