Old 12-02-2025, 08:15 AM   #1
mike16
72 c10 non ac heater hose lengths
I have a 1972 c10 with the standard 307/4spd.
It does NOT have AC.
What is the correct length for the 5/8th's and 3/4 inch heater hoses?
Thank you all and happy holidays
mike16 is offline   Reply With Quote
Old 12-02-2025, 07:03 PM   #2
mr48chev
mr48chev's Avatar
Re: 72 c10 non ac heater hose lengths
Before heater hose got so expensive I just would tell them to give me 4 ft of each and trim to look right and save the stub ends. I don't have a small block in mine any more so I can't measure it and give you accurate measurements.
My ongoing truck projects:
Old 12-02-2025, 09:40 PM   #3
mike16
I'm going with the factory appearing heater hoses and it sells by the foot.
Old 12-03-2025, 11:48 AM   #4
geunther
geunther's Avatar
Top from heater box which goes to water pump = 34.75"
Bottom from heater box which goes to intake = 41".
I cannot say they are original but I previously verified they follow the build manual routing. Also do not let the tape rub up against the positive terminal.
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
Old 12-04-2025, 01:49 AM   #5
G-749
Active Member
Talking Re: 72 c10 non ac heater hose lengths
Lmao about the tape measure, wish I would have kept the pocket knife that didn't survive the arc test on my 69 SS Camaro, took couple of weeks for the blisters/ skin to grow back
70 C 20 Longhorn PS , PDB, Dealer installed AC, 700 R4, Dual battery, original TAX 350 motor, 3rd owner truck.
71 C 50 292 4sp 2sp vacuum operated rear end 8 x 12 flat bed.
22.5 Goodyear radial$ n Wheels Now rim$
86 Grand Wagoneer " Saggy Waggy " Jeep = Just Empty Every Pocket $$$ currently in another shop
G-749 is offline   Reply With Quote
Old 12-27-2025, 10:32 PM   #6
geunther
geunther's Avatar
Apologies, I did some research and I gave you the wrong length. After looking through my pics, I realized mine are too long. Attached is a pic of one of the Lambrecht auction trucks during disassembly. It probably had less than a couple of hundred miles. Though I do not know the length, you can see how short they would be.
