Old 12-08-2025, 02:44 PM   #1
raidmagic
raidmagic's Avatar
Corner speaker boxes
Anyone use these or ones like them? Thoughts on sound quality? Install? Do they screw in?
https://www.ebay.com/itm/28590653977...YaApNXEALw_wcB
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 12-08-2025, 11:03 PM   #2
karlbenz
Re: Corner speaker boxes
wouldn't open for me?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 12-09-2025, 09:54 AM   #3
1964FarmFreshC10
thats not a valid link
1964FarmFreshC10 is offline   Reply With Quote
Old 12-09-2025, 11:50 AM   #4
SkinnyG
SkinnyG's Avatar
ebay item# 285906539775
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-09-2025, 12:02 PM   #5
1964FarmFreshC10
weird still doesn't work. Just a black screen
Old 12-09-2025, 12:07 PM   #6
Getter-Done
Getter-Done's Avatar
Ebay links have not been working for awhile now.
Search terms : 1960-1966 Chevy Truck & GMC Cab Corner 6x9 Speaker Brackets
Seller : motorcity-sheetmetal
The early bird gets the worm,
85 Chevy K-20
Old 12-11-2025, 12:28 PM   #7
raidmagic
raidmagic's Avatar
Sorry guys, been busy. Not sure why the link doesn't work. They are sheet metal 6x9 holders that place the speakers on the cab corners.
Old 12-11-2025, 01:36 PM   #8
racecougar
racecougar's Avatar
I did something similar. I built speaker boxes that fit tightly into the cab corners; no drilling/screwing necessary. They sound great.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-15-2025, 08:42 PM   #9
cj847
cj847's Avatar
I put a set in my 67. There were no instructions. So, I lined the area with sound deadener; screwed it to the back wall (2 screws). The other edge tucks under the cab weatherstrip so I didn't want to put a screw there. Instead, I put a little rtv between the joint to prevent vibration. Also stuffed the cavity with jute or other insulation. It sounds surprisingly good.
NOTE: I had the 6x9's in boxes facing up behind the seat, but after my truck spent time in paint purgatory, I found out why that's a bad idea's. Also, I'm running a 1000 watt (well that's what they claim) 4 channel amp and a powered subwoofer. In my noisy truck I don't think I could hear anything if it wasn't amplified significantly.
cj847 is offline   Reply With Quote
Old 12-16-2025, 10:44 AM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
For $85, I will build my own probably out of plywood. maybe 1/2"
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-16-2025, 12:39 PM   #11
racecougar
racecougar's Avatar
Ditto. I stuck an amp under the passenger seat.
Old 12-16-2025, 02:34 PM   #12
jayoldschool
Moderator
Is that the molded rubber floor? I put that in my truck as well, it made a huge difference for the in-cab sound level!
jayoldschool is online now   Reply With Quote
Old 12-16-2025, 03:09 PM   #13
racecougar
racecougar's Avatar
It's the molded vinyl floor from stockinteriors.com (link to it below). I've been happy with it. I believe I installed it around 2016.
https://www.stockinteriors.com/moldedvinyl/13104
Old 12-16-2025, 09:49 PM   #14
raidmagic
raidmagic's Avatar
Thanks for the replies.
