Old 12-10-2025, 12:51 AM   #1
Loose Screw
Loose Screw's Avatar
Parking Brake Felt Piece, where does it go exactly?
LMC's diagram shows close or at drum (#6), I can't figure out exactly where....
Loose Screw is offline   Reply With Quote
Old 12-10-2025, 12:49 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Parking Brake Felt Piece, where does it go exactly?
Only thing that makes sense is if your Park Brake cable bolts to the backing plate like on a 3/4 or 1 ton. If it uses a tension clip through the hole, then it does not belong on that application. LMC should clarify that in the catalog.
What year are you working on?
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-10-2025, 01:07 PM   #3
daddymoo2
The felt part attaches between the backing plate and the parking brake cable on 3/4and 1 ton trucks. Hope this helps.
daddymoo2 is offline   Reply With Quote
Old 12-10-2025, 01:21 PM   #4
Loose Screw
Smitty
The truck is a 1968 C10...
Old 12-10-2025, 01:26 PM   #5
Loose Screw
Well, I just acquired a part I really don't need. I've dirtied it up some, for 3 bucks I don't know if I'll hassle with a return. I will let LMC know though some day.
Thanks Everybody!
Old 12-10-2025, 01:36 PM   #6
71meangreenc10
No worries.
Smitty
71 C30 Wrecker
Old 12-11-2025, 08:46 AM   #7
chewychevy67
That also works on 67 and 68 gmc 1/2 ton trucks with a dana 44 rear diff
chewychevy67 is offline   Reply With Quote
