Old 12-13-2025, 03:25 PM   #1
CG
BlahBlahBlah
Frame swap questions
Im sure this has been asked before but Im hoping someone knows right off the top of their head. And I realize some of you might think this is a bad idea but that isnt the question.
A friend just called me and asked this. He wants to know if you can take body off of a 68 K Burb and put it on a 72 C coil spring truck chassis. Wondering what all he has to change.
Then he wants to know if he can put a 71 truck cab and box on the 68 K Burb chassis. Ending up with a 4x4 truck. Again what all needs to be changed.
I think hes hoping maybe only the rear frame horns and body mount points need to be changed for both of these swaps to work.
Thanks for any insights!
Old 12-15-2025, 08:48 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Frame swap questions
Park Brake System (handle vs foot) Throttle linkages (cable vs rod) Rear light harness is routed different for the truck vs burb, Fuel tank and lines, If I am right there is a difference in the rear mounting tabs for the C and K Burbs. My buddy has a K and I can ask him because we went through that and he came and checked a C frame I had. We have both frames and it wont be hard to compare them.
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-16-2025, 12:18 PM   #3
HO455
HO455's Avatar
I know that the Suburban rear frame horns are different than the pickup ones to put the sport bumper in the proper location for a Suburban. Mounting of a standard step bumper requires modification of the Suburban frame.
I also remember reading here some time back that the shape of the frame rails under the box of a pickup are quite different than a Suburban.
RIP Bob Parks.
Old 12-16-2025, 07:31 PM   #4
CG
BlahBlahBlah
Smitty some of those I didnt even consider.
I thought I had read that too about the frame shape.HO455
Appreciate the input fellas!
Old 12-16-2025, 08:51 PM   #5
71meangreenc10
Good Stuff!! I have a coil spring 2wd truck frame and my friend has a 4wd burb frame, we can check the rear frame rails to see if there are issues with the bed mounting as stated above if you want me to.
Smitty
71 C30 Wrecker
Old 12-16-2025, 10:15 PM   #6
CG
BlahBlahBlah
Ill ask my buddy first, I appreciate the effort but you dont need to do anymore leg work (yet lol). Someone he has been dealing with for awhile offered him a trade for a later model (90s I think) 3/4 ton truck he's been sitting on. Stuff he wants to trade is the 68 burb 4x4 a 71 truck cab and a bunch of other 67-72 truck stuff. Sounds like the Burb has some rust issues so he's not going to make a decision until he sees it in person and that wont be until after the holidays.
Old 12-16-2025, 11:37 PM   #7
71meangreenc10
No issue.
Smitty
71 C30 Wrecker
