67-72 Chevy/GMC Shortened Floor Shift Tilt Steering Column
67-72 Chevy/GMC shortened floor shift tilt steering column. The steering column was an automatic column originally & been converted to a floor shift column & shortened 2” to give you more room in the cab between the steering wheel & the seat. The column was stripped down & checked for worn or broken parts & replaced if needed. Column was painted back black & reassembled using the following new parts. Turn signal switch & wiring harness with the correct curved wire connector, lower bearing, lower bearing retainer, cancel cam/ horn contact, tilt & turn signal lever& hazard light knob.
$650.00 Plus Shipping / Payment / Postal Money Order or Personal Check
