Old 01-07-2026, 11:24 AM   #1
Perpendicular
Starter wiring cleanup
What is everyone doing with the wiring to the starter to clean it up, protect it?
I remember, back in the day, there was a metal conduit you installed. I hated those and usually removed them, but now I can appreciate the part.
https://www.ebay.com/itm/25693173797...NVVQAYtYX0pBwI
Thoughts / ideas on what everyone else is doing?
Perpendicular is offline   Reply With Quote
Old 01-07-2026, 01:44 PM   #2
kwmech
Re: Starter wiring cleanup
I am using a remote solenoid, so all I have going to the starter is the 2ga batt cable and the jumper. Cable is sheathed
Old 01-09-2026, 09:01 AM   #3
RustyPile
RustyPile's Avatar
That conduit piece performed its function very well. The piece is out there, you just have to do a diligent search for it.
RustyPile is offline   Reply With Quote
Old 01-09-2026, 02:14 PM   #4
weq92f
weq92f's Avatar
I've got the metal conduit and it keeps the wiring off/away from the headers.
When I was putting it all back together this and the mechanical, passenger side exhaust flapper were two bits I wasn't going to reuse...reconsidered the tube and it works well.
First page of this result set has some examples:
https://www.google.com/search?q=earl...CAIQAhgCIAIoAg
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-12-2026, 05:17 AM   #5
Killer Bee
Killer Bee's Avatar
this.
if not a factory restoration, I'd recommend converting to one wire starter by installing the ford style remote solenoid. this relocates lighter gage wiring out of harms way when running headers or other mods. also easier for wire management or clean-up. hundreds of how-to diagrams and pictures on the interwebs.
as for the tube, I searched "small (or big) block chevy starter wiring tube" and several different forms of them showed up. don't limit searches for truck parts only, many sedans had these from the factory. being an engine mounted part, one of those may suit your needs.
good luck!
Old 01-12-2026, 11:09 AM   #6
mike16
Wipe it down with go jo hand cleaner.
Put it in a zip lock bag with some ArmourAll.
You can get hi temperature protective sleeves, by the foot , from aircraft spruce and specialty co.
If certain wires need to be replace aircraft spruce also sells very high quality wire in various colors and guages. Those unique gm style wire ends are readily available both individually and in bulk.
mike16 is offline   Reply With Quote
Old 01-15-2026, 08:19 PM   #7
425HP409
425hp409
425HP409's Avatar
This is what I did on my 68 with the 396 install. The heat shield mounted to the solenoid and the front starter brace bolt. You will see why something is needed when you see how close the exhaust manifold is to the starter and solenoid. The battery cable runs on top of the frame and then is bolted to the starter as in photo 4&5. The engine starter harness comes down the firewall and runs under the heat shield away from the exhaust. I added a rubber hose as insulator on the engine harness.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Oldsmobile 442, all original
425HP409 is offline   Reply With Quote
Old 01-15-2026, 09:01 PM   #8
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
That heat shield was there when I replaced the starter on my truck, but I went with a mini starter and did not reinstall the heat shield. Since I got the engine's hot-running habits over with, I don't need that shield.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-16-2026, 02:36 PM   #9
Jason Banks
Jason Banks's Avatar
I used some of this fiberglass braided wrap - https://www.mcmaster.com/88175K32-88175K52/
Jason Banks is offline   Reply With Quote
Old 01-16-2026, 03:39 PM   #10
Rust_never_sleeps
Rust_never_sleeps's Avatar
DEI has good materials
https://www.designengineering.com/he...form-a-shield/
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 01-16-2026, 04:10 PM   #11
A1971Blazer
A1971Blazer's Avatar
I used the aluminum split loom from McMaster
https://www.mcmaster.com/2652K34/
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
